Sponsored by: Real Truck
Need help
Old Aug 8, 2015 | 06:23 PM
busdriver47's Avatar
busdriver47
Cool Need help
My front hubs will not engage
Old Aug 8, 2015 | 06:24 PM
Diamnd1's Avatar
Diamnd1
Try taking them off to inspect or clean.
Old Aug 9, 2015 | 06:34 PM
Tom A's Avatar
Tom A
Are they vacuum-actuated? Check the vacuum hoses to be sure they aren't rotted or disconnected. Do they work if you engage them manually?
Old Aug 10, 2015 | 06:14 PM
HearseDriver's Avatar
HearseDriver
Year? Gas/Diesel? As stated earlier - remove, clean, inspect, grease & reinstall front hubs. No need to jack up the truck or remove the wheels. Just 3 Torx screws and they come right off. Vacuum leak? check your plastic & rubber hoses from your PVH Valve (Pulse Vacuum Valve) all the way down to your hubs. I found my factory plastic line melted at the frame near the starter (6.8 Gas Motor) where it was only 2 inches away from my exhaust manifold. I ended up bending up some 3/16" brake tubing to replace it. I can guarantee it's not going to melt ever again. Make sure you have at least 9.8 Volts to the center pin on the PVH valve connecter. Let us know what you find. If you have a diesel check to see that your vacuum pump is running and you have vacuum. Hope this helps.
firegod42
Aug 10, 2017 12:08 PM
Cryptmaster
Jun 27, 2017 10:23 PM
theduke308
2004 - 2008 F150
Jul 21, 2012 07:47 PM
onephinesuperduty
Aug 24, 2009 10:35 AM
palmer8996
Modular V10 (6.8l)
Apr 17, 2009 06:14 AM
