Sponsored by: Auxito
overdrive light flashing
Old Dec 8, 2015 | 06:55 PM
KING-RANCH02's Avatar
KING-RANCH02
i know this has been a topic before but my truck has none of the symptoms described. it flashes but at no certain time or any particular instance. it dont happen everyday only occasionally. transmission was rebuilt with heavy duty clutches torque converter and towing shift kit and has 70k miles. this has been going on for a month. fluid is not getting hot running around 130 degrees with 2 large coolers only code it threw was tcc solenoid "slip greater than expected". changed the solenoid and shift solenoids and still flashing. havent made it to a scan tool since i replaced the parts and plan to just didnt know if anyone had any ideas. it does not shift differently or act out of the ordinary while light flashes. trans has been serviced at time of solenoid replacement about 400 miles ago. kind of annoying and would like to solve the issue if anyone has any input all would be appreciated.
Old Dec 8, 2015 | 09:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I have an idea! Get the codes read so you'll know where to start.
Old Dec 9, 2015 | 06:32 PM
KING-RANCH02
its throwing code po741 torque converter circuit performance or stuck open. just replaced this part less than a week ago.
Old Dec 9, 2015 | 08:43 PM
Mark Kovalsky
What part? It could the the solenoid, the valve, the seals, or even the torque converter.
350Fitter
May 3, 2018 08:28 PM
Birney
1997 - 2003 F150
Mar 17, 2017 10:17 AM
Black_6.0
Aug 10, 2015 05:57 PM
F150vettehauler
2004 - 2008 F150
Jun 21, 2014 06:31 PM
f350ranchand
Nov 11, 2012 08:54 PM
