01 4r100 no reverse
Old Jun 23, 2015 | 08:13 PM
78fordman's Avatar
78fordman
01 4r100 no reverse
my parents have a f350 which now has no reverse. it has a reman sticker on it, 230k on the truck but no idea on mileage on the tranny. shifts 1st through 4th fine, no slip. Tc lockup works just fine. no codes found with my solus scanner. when shifted in reverse it will move back about 2 ft if reved above 2k and then nothing. Am I looking a trans rebuild or is there something I can check and repair with in it the truck?
Old Jun 23, 2015 | 09:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a slight possibility that the feed bolts between the valve body and case have loosened. But revving it to 2k to get it to move might have made that check moot. If the clutch was partially applying, revving the engine like that for more than 1-2 seconds will totally destroy the reverse clutch. I suspect you need a rebuild, even if you didn't when this first happened.
Old Jun 24, 2015 | 07:13 AM
78fordman's Avatar
78fordman
Thanks for the help, We will pull the trans.
Old Jun 24, 2015 | 07:08 PM
DieselDenny's Avatar
DieselDenny
When your pissin out your ***, you go to the surgeon.... Going to rep island!
Old Jun 24, 2015 | 07:25 PM
Pikachu's Avatar
Pikachu
That is nasty and completely inappropriate.
Wild-Bill
Dec 12, 2013 05:56 AM
fordbogger77
May 31, 2013 12:10 AM
elotus
Aug 25, 2011 08:23 PM
Justin's Green Truck
1997 - 2003 F150
Nov 28, 2010 07:27 AM
jas88
18
Oct 4, 2008 04:50 PM
