Sponsored by: Real Truck
Trouble With Reverse
Old Aug 25, 2011 | 06:56 AM
elotus's Avatar
elotus
Hello,
My '03 F250 is experiencing intermittent problems engaging reverse. When I shift into reverse, I have to rev the engine for reverse to engage. It only appears to happen after I've driven home from work, 30 miles, let the truck sit for a few minutes, and attempt to pull out of the driveway. I've discovered that if reverse does not engage, I can shift into drive, which engages, then back into reverse. This usually allows reverse to engage. Has anyone else experienced this?
Vehicle Details:
2003 F250 - stock
V10
3.73 gears
110,000 miles
Thanks in advance for any advice.
Old Aug 25, 2011 | 01:38 PM
elotus's Avatar
elotus
Bump for some help.
Old Aug 25, 2011 | 05:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think you may have a damaged seal in the reverse clutch. It could also be loose feed bolts between the valve body and trans case. Or going with the simple possibility, low trans fluid could do this, too.
Old Aug 25, 2011 | 08:23 PM
elotus's Avatar
elotus
Thanks for the reply, I'll start with the simple first.
rock2610d
Sep 8, 2018 06:41 AM
evan1242
Aug 7, 2015 02:43 PM
Rockafella
Feb 15, 2003 09:09 PM
