1978 - 1996 Big Bronco
Can't pull engine codes
Old May 18, 2015 | 06:17 PM
quentin24's Avatar
quentin24
Start off by saying it's been a LOOONG time since I've been here. Switched trucks quite a bit since then. Now have a 1990 Bronco XLT 5.8 with 80k original miles.
Can't get it to go into code mode. Tried the trick with grounding the code wire. Still won't do it. But here's what I know:
-Won't start without starter fluid
-Turn the key to run and the pump runs, but doesn't shut off
-There is gas
-If I push the bleeder nozzle on the fuel rail while the pump is on, fuel will dribble out but not spray hard (low pressure?)
-Can't pull any codes and not sure why (don't have a check engine light just wondered if there was something there) Won't enter the flashing mode at all.
Any other help would be awesome. Thanks!
Old May 19, 2015 | 08:01 AM
rla2005's Avatar
rla2005
-There is gas
The items in bold above are classic symptoms of a failed computer. Pull out the PCM (computer), open it up and inspect for signs of leaking capacitors. Another very common problem.
Old May 19, 2015 | 09:29 AM
quentin24's Avatar
quentin24
Thanks and I'll check it out. Just need to know where it's located. Drivers kick?
Old May 19, 2015 | 09:33 AM
rla2005's Avatar
rla2005
Yes sir
courtesy of subford
It comes out from inside the cab on your model year truck.
Old May 19, 2015 | 09:59 AM
quentin24's Avatar
quentin24
The guy I bought it from put a brand new battery in 2 weeks ago and hadn't driven it. Wonder if that fried something.
Anyway, was poking around and this Bronco is amazing. No rust and doesn't look like anyone has molested a thing on it. Found the build sheet under the back carpet which is original yet looks new. Think I got a good deal at $1,800?
Old May 19, 2015 | 10:20 AM
quentin24's Avatar
quentin24
One more thing!! Is the PCM the same as the EEC/ECM? I'm reading that there is also a computer behind the kick panel.
EDIT: N/M Same thing.
Old May 19, 2015 | 11:34 AM
quentin24's Avatar
quentin24
So yep, leaking capacitors in the ECU.
Do I need the exact F0TF PD model? Hoping to go to a junk yard and find one instead of forking over the $120.
Old May 19, 2015 | 12:32 PM
rla2005's Avatar
rla2005
F0TF-PD is a PCM for a 5.8L bronco w/E4OD transmission AND California emissions. If you live in Cali. you need one of those. If not you could look for a similar year PCM from a Bronco/F150 with a 5.8L/E4OD combination. Approximately 1988 to 1993.
You could send yours to this place to be repaired: http://www.ecurepairnow.com/
Old May 20, 2015 | 04:42 PM
quentin24's Avatar
quentin24
New computer installed. Fired right up. Thanks.
Old May 20, 2015 | 09:50 PM
rla2005's Avatar
rla2005
Glad to see you got it going. Thanks for the feedback.
You are welcome
Bronco_lover1488
Dec 11, 2018 11:11 PM
daltonjr
15
Aug 7, 2010 04:32 PM
GUelkman375
May 29, 2009 12:51 PM
mirrormaker
Apr 27, 2005 11:45 AM
marcia
1983 - 2012 Ranger & B-Series
Jan 1, 2005 05:34 PM
