truck doesn`t run
Old Jul 10, 2010 | 01:07 PM
daltonjr's Avatar
daltonjr
truck doesn`t run
I`m new to here I have a 93 f150 xlt 4x4 351 automatic it would run for a little bit then shut off now doesn`t run at all. So thinking it was the fuel pump changed it, still same problem disconnected the fuel line at the pump turned on ignition pump ran may 2 secs. then shut off. Reset inertia to be sure no change everything else works no codes to be found. Any ideas?
Old Jul 10, 2010 | 08:28 PM
subford's Avatar
subford
The pump is only going to run one second when you turn on the key so that is normal.
You need to see what codes you have in CM in the computer.
Check for spark and if you have none unplug the PCM Computer and check again and if spark returns you have a bad computer.
If still no spark I would guess you have a bad Coil, PIP sensor or ICM but check your codes first and see what they say.
Old Jul 11, 2010 | 01:46 PM
daltonjr's Avatar
daltonjr
I have fire, fuel pressure my codes are 33, 133 or 331, 33 the 33 is egr code I measured ohms the book says 5000 mine is 3000 will the low ohms make the truck not start? codes 133 and 331 are not listed in my book
Thanks for the help!!!!
Old Jul 11, 2010 | 01:49 PM
84f250460's Avatar
84f250460
have you checked the FPR? i just had a similar issue and it turned out that was the problem
Old Jul 11, 2010 | 02:01 PM
daltonjr's Avatar
daltonjr
I have 3 relays in the power box which one is for the fuel
Old Jul 11, 2010 | 08:00 PM
84f250460's Avatar
84f250460
i was referring to the regulator itself, im not sure which relay it is
Old Jul 11, 2010 | 08:42 PM
daltonjr's Avatar
daltonjr
Thanks I will check it tommorow night
Old Jul 18, 2010 | 08:09 PM
daltonjr's Avatar
daltonjr
I changed the fuel regulator no change anymore ideas? still have fuel pressure and spark at the plugs
Old Jul 25, 2010 | 09:03 PM
daltonjr's Avatar
daltonjr
I changed icm,coil, tad,tab sensors code is 111 which is systems passes no change i still have spark and fuel but still doesn`t start any ideas out ther?
Old Jul 26, 2010 | 08:00 AM
subford's Avatar
subford
Put a noid light on one of the injector plugs and see if flashes when you crank the engine.
Old Jul 26, 2010 | 08:08 AM
rla2005's Avatar
rla2005
I see you have replaced a fuel pump, FPR and various other parts. Have you confirmed what the fuel pressure is? You state you have spark, could you clarify where you checked it as well as the color (yellow, blue, etc.)?
Old Jul 28, 2010 | 08:01 PM
daltonjr's Avatar
daltonjr
I have spark at the plugs i pulled the wire of of # 2 put a screw driver in it and turned the engine over watched the blue spark. I don`t have a noid light yet can i get them at parts stores, walmart or both? Thanks for the help!!!!!!
Old Jul 28, 2010 | 09:28 PM
subford's Avatar
subford
You can rent a noid light at most auto part stores.
Old Jul 28, 2010 | 09:34 PM
wickedklown83's Avatar
wickedklown83
i know it isnt as accurate but i grounded a test light and put it on the 2nd wire of the injector ( not the solid red wire ) and has a friend crank the engine and it kinda pulsed, its a cheap *** way to see if it is firing injectors at the harness, but not exacctly accurate as to tell you if it is pulsing quick enough
Old Aug 4, 2010 | 07:15 PM
daltonjr's Avatar
daltonjr
checked the injectors with anoid light, injectors are good but spark was orange this time battery is charged, would this be a coil pickup issue? is there a way to check it or just replace it? Again Thanks for everyone`s help!!!!!!!!!!!!!!
