HELP!!! truck starts but wont stay running!
I have a 1991 bronco, and it wont stay running! It will start up, and stay running long enough to move quickly, but will just putter and die. after it dies it will not restart, it will turn over, but not start. if i let it sit for a while, it will start back up again, and do the same thing. does anyone have any help they could offer me? anything and everything is appreciated!
~Elkman
~Elkman
The "codes" are information trouble codes stored in the Engine control unit aka computer, ECU, ECM. There are a few ways to get the computer to "read" the codes out to you. One way is the "paper-clip" method discribed in a haynes manual, FAQ to this sectionl, or at fordfuelinjection.com. I believe fordfuelinjection discribes this method very well as many people have used it to great success.
My experience has been with counting the flashes that show up either on the CEL light flashing or a reader. It takes a bit of practice to get use to reading the lights but longer pauses represent a new number, short pauses happen between the first and second digit. With a repeat of the numbers before moving from initial reading to continuous memory reading of trouble codes.
ok I will give this a try this weekend. I want to say that it could be a fuel pump, or injector/relay issue of some kind, because it has power everywhere, but dies like it is running out of fuel after a couple of minutes. there was also not a distinct event that caused it. I shut the truck off, and about a month later after I got home from school it was like this.
Does it start with Ether sprayed in the intake? If so it's a fuel delivery problem, if not look to spark timing/compression. Tho if it was running and didn't sound like the timing chain broke then it's likely to be a spark problem. I had to rebuild the distributor on my 90 Bronco after it started acting up and then stopped altogether.
Ford Fuel Injection has instructions on doing this with out leaving the house using a paper clip and counting the flashes. some auto stores wont help ya like they used to.
it starts up, but it just does not stay running for more than a couple of minutes. it has plenty of compression, and there is no indication that the timing chain is broken. also, there is plenty of spark...we pulled the plugs and tested them all, and they work. g_k, what were the symptoms when your distributor went out?
It was acting like it was running out of fuel. It was intermitant. Stopped completely one time and had it towed back to the house. It started working again while I was troubleshooting the ignition system using a Haynes manual. It stopped a few days later and wouldn't start again. I had to rebuild the distributor down to the stator, used all new parts. Now it runs but still has power issues.
Ant Go
01-23-2017 01:20 PM
Matthew Wilson
13
01-05-2016 12:07 PM
Weeks7524
12-18-2015 11:28 AM
Muddominator
09-24-2011 11:00 AM
beartooth1
12-05-2004 09:35 PM
