Arm Rest Mount Inserts
Old May 14, 2015 | 03:11 PM
Flat Ernie's Avatar
Flat Ernie
Anyone have a source for these? I'd like to put an armrest on the driver's side, but it didn't have them originally on my truck.
Old May 14, 2015 | 07:34 PM
drptop70ss's Avatar
drptop70ss
how about welding up those holes and installing riv-nuts? Or just bend a couple up out of sheet metal?
Old May 15, 2015 | 07:51 AM
Flat Ernie's Avatar
Flat Ernie
Rivnuts won't work easily because the screws go in at an angle - hard to see in the pic.
These things are made of spring steel so they 'snap' into place. The driver's side doesn't have the openings for them, but those would be easy enough to cut in. If I could find a second set of these, I'd be set.
Old May 15, 2015 | 11:48 AM
CharlieLed's Avatar
CharlieLed
I have removed a bunch of those but I can't say that I could get my hands on a pair now. If I stumble across a pair I'll hold them for you.
Old May 15, 2015 | 03:48 PM
fladoodle's Avatar
fladoodle
I should have a pair in a door somewhere.. If I find them, I'll send them for postage
Old May 15, 2015 | 06:35 PM
Smitty49's Avatar
Smitty49
Can these listed at MidFifty be modified to fit your truck?
1953-56 Ford F-100 Arm Rest Clip, Stock Rectangular Hole - 7024146-A
Old May 16, 2015 | 12:41 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Those look just like the OP picture...
Old May 16, 2015 | 08:11 PM
Flat Ernie's Avatar
Flat Ernie
That looks like the deal! I had looked at Mac's, but not mid-50s! THANKS!
Old May 17, 2015 | 10:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That looks like a quick way to add them to a 48-52...
Old May 18, 2015 | 02:08 PM
Flat Ernie's Avatar
Flat Ernie
My 51 F1 panel had them on both doors from original...
Old May 18, 2015 | 02:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, but mounted with a more elaborate piece that AFAIK is not repro'd
Nicmike
Feb 23, 2020 08:52 AM
GJCAT
Oct 29, 2016 04:10 AM
ch4rlie
Escape & Escape Hybrid
Jun 29, 2015 09:38 PM
84espy
Mar 4, 2013 05:33 AM
Old Rusty Wrench
All Things Towing
Sep 19, 2009 07:06 PM
