sun visers keep droping
Old Oct 28, 2016 | 08:27 AM
GJCAT's Avatar
GJCAT
I put new arms and repop visers on my 56. The things keep dropping when I drive it. Any ideas on tightening them up to stay put? The interior is stock appearing.
Old Oct 28, 2016 | 08:52 AM
Mr. Ed's Avatar
Mr. Ed
If they are swinging down from the roof mount, the spring tension on the arm has weakened over the years. I had similar problem on my Spirit. I took the mount down from the roof and put the arm securely in a vise with the spring sticking up. You should see a washer on top of the spring that is held in place by a flat spot on the end of the arm. Now take the appropriate size "C" clip and snap one on the arm under the washer, compressing the spring, increasing the tension on the arm. Re-install the visor and if it still swings down, remove and add another "C" clip.
Later!
Mr. Ed
Old Oct 28, 2016 | 10:58 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
It sounds like he is saying the visor is dropping Ed. The spring trick would keep the arm from freely rotating.
Take the visor off the arm and place it on a solid bench, put a piece of wood or metal on top of the visor where it slides on the rod then hit the wood/metal with a hammer to change the diameter of the tub that slides on the rod. Do a little at a time so you don't crush it to the point you can't get it back on the rod. Number one don't lube anything on the visor or mount.
Old Oct 28, 2016 | 03:04 PM
GJCAT's Avatar
GJCAT
The arm tension is fine. Its the visor itself that drops. I will pull them off and try the hammer trick Thanks
Old Oct 28, 2016 | 07:45 PM
56panelford's Avatar
56panelford
Slide the visor off the arm and put a slight bend in the arm, I had the same problem with the new ones I put in my panel..
Old Oct 29, 2016 | 04:10 AM
_Chuck_'s Avatar
_Chuck_
I taped a small rare earth magnet to the top-side of the visor.
19fifty4
16
Dec 14, 2015 06:00 AM
MY FYN 79
Oct 18, 2015 04:13 PM
yellow72f100
Jul 11, 2006 12:34 PM
HighProCam
15
Jun 22, 2005 04:42 PM
nightowl_52
15
Apr 30, 2004 05:21 AM
