A little disappointing....
Old Jan 16, 2016 | 08:12 AM
  #106
ultraranger's Avatar
ultraranger
Originally Posted by 351Cleveland C4
Right. So if that's the case, 1/4 mile times should have been closer to 14.5 @ 93.
I ran a consistent 15.9-16.0 @ 83. Figuring a 4300lb race weight, that suggests 200hp.
Look at it this way, considering your engine isn't an all out race engine, your truck weighs over 2 tons and has the aerodynamics of a barn door, high 15s in 1320 feet isn't too bad for a 'work' truck.
Old Jan 16, 2016 | 08:33 AM
  #107
351Cleveland C4's Avatar
351Cleveland C4
Yeah, I guess so.
Old Jan 16, 2016 | 09:20 AM
  #108
MIKES 68 F100's Avatar
MIKES 68 F100
driver error ? Lol just kidding don't dis my DD5
Old Jan 16, 2016 | 03:52 PM
  #109
351Cleveland C4
I would like to race again and try to go faster. This time with a better setup.
Old Jan 17, 2016 | 01:05 PM
  #110
ultraranger
Get a pair of wheels and mount as big a set of sticky drag radials on them as will fit in the rear wheel wells without rubbing. This will make a big difference in how fast the truck comes out of the hole. It will reduce your 60ft times as well as reduce your overall E.T.
Hard street tires aren't good for getting the power to the ground under a hard launch.
Old Jan 17, 2016 | 01:11 PM
  #111
351Cleveland C4
I think my 31s aired down to 10psi or so will hook ok. Last set I was on we're bald and petrified.
Old Jan 18, 2016 | 06:28 AM
  #112
GaryKip's Avatar
GaryKip
But the thing is the tire compound of street tires is made for more mileage that just grip. So Unless you can get those 31's really hot and sticky (which will ruin them for normal driving) you need track tires or "slicks" to get the most speed.
Old Jan 18, 2016 | 02:48 PM
  #113
351Cleveland C4
True. But I'm betting they'll work pretty good.
Old Jan 18, 2016 | 02:49 PM
  #114
yetiman38237's Avatar
yetiman38237
I remember seeing a canary yellow F100 at the 1/8 mile track where I used to run. He had that truck hooking up big time. Don't remember what he ran but it would tote the tires out of the hole. Kind of a strange drag machine if you ask me (and you didn't) but was way cool.......
Dave145
22
Jan 7, 2014 09:36 PM
packlet
Dec 20, 2004 03:39 PM
1TUFFBRONCO
16
Jun 15, 2004 10:14 PM
fordfan2018
18
Feb 15, 2004 11:04 AM
stryder
Aug 2, 2000 06:06 PM
