Mercon LV?
Old Apr 5, 2015 | 11:34 PM
IHateCommieCars's Avatar
IHateCommieCars
Mercon LV?
I can't find any SP at the local auto parts stores. Read at dieselstop that LV has been approved to replace SP. Is anyone using LV? Where do you buy SP?
Old Apr 6, 2015 | 05:44 AM
Excurvelle's Avatar
Excurvelle
I am running LV in my Ex, no problem. The dealers still carry SP but LV is the direct replacement.
Old Apr 6, 2015 | 06:44 AM
npccpartsman's Avatar
npccpartsman
Just did my regular service with LV for the 3rd time when I installed the 08 tranny pan and filter. Absolutely no problems running it and it was less than SP at the parts store.
Old Apr 6, 2015 | 07:50 AM
IHateCommieCars
Thanks everyone. That's what I needed to know.
Old Apr 6, 2015 | 01:11 PM
diesel_dan's Avatar
diesel_dan
Just in case you need to hear one more: When I did the '08 pan/filter conversion both SP and LV were available and still the same price. I put in 9 qts of LV, so the balance in there is SP. No, nada, not a single issue -- I will stick with the LV for future Torqshift fluid changes...
Old Apr 6, 2015 | 01:16 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I've started using Maxlife ATF
(Ducks out of the way)
Josh
Old Apr 6, 2015 | 04:45 PM
Piolet's Avatar
Piolet
Make some popcorn and read ...
https://www.ford-trucks.com/forums/9...lv-and-sp.html
Old Apr 6, 2015 | 05:02 PM
Per4mance's Avatar
Per4mance
From what I've read, Maxlife is the direct aftermarket replacement for SP and LV.Never tried it and have no experience with it, but if it works for Josh I'll give it a shot
Old Apr 6, 2015 | 05:15 PM
Bullitt390's Avatar
Bullitt390
Looking at the specs its darn near identical to LV. SP is surprisingly a very thin fluid.
Josh
Old Apr 6, 2015 | 05:18 PM
Per4mance's Avatar
Per4mance
I'm long over due for a a trans service,with that being said,I just ordered a 08 trans pan and filter and will use Maxlife.........only time will tell.
Old Apr 6, 2015 | 09:05 PM
david0505's Avatar
david0505
mercon sp
You might want to try O'reilleys or diesel filters online...both usually have sp...Dave
Old Apr 6, 2015 | 09:15 PM
bismic's Avatar
bismic
Dieselfiltersonline is a good place to shop. They will ship free if over $250 (IIRC). Their price is $6.59 a quart for SP and $5.47 for LV.
AutoNation White Bear Lake sells it for $5.79 a quart (in shipments of 12). Shipping is reasonable if you buy from them through FordParts.com. Their LV price is $4.71 a quart.
Old Apr 7, 2015 | 02:18 AM
Yahiko's Avatar
Yahiko
Ed's price should be near or lower that White Bear.
Sean
06yz125
Apr 15, 2010 08:45 PM
cartmanea
May 30, 2008 07:35 PM
greagin
Oct 25, 2007 04:44 AM
Pocono Super Duty
Sep 12, 2007 06:36 PM
sfc11b
Aug 12, 2007 08:04 AM
