Accelerating Problems
Old Mar 21, 2015 | 08:38 PM
kenworth01's Avatar
kenworth01
Hey new to diesels just put cold air intake on it ran fine after I put it on for the first couple rides now when accelerating it sounds like its sputtering or I'm pulling an elephant until get it past 2 thousand rpm or about 40km then goes back to normal any ideas what it could be ?
Old Mar 21, 2015 | 09:55 PM
coreyallan01's Avatar
coreyallan01
Its probably a coincidence but sounds like the EBPV is sticking.. Im pretty sure thats what your talking about.. Use the search feature, youll find a bunch of write ups on it..
Old Mar 21, 2015 | 10:13 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
You can disconnect the ebpv. There is a 2prong plug along the driver side valve cover going to the turbo.
Old Mar 22, 2015 | 02:47 PM
kenworth01's Avatar
kenworth01
So unplugging that will fix the problem and any set backs to that ? How expensive is it to fix it ?
Old Mar 22, 2015 | 03:18 PM
MOOSE_MACHINE
it will not really "fix" your problem. It will only tell you if that was/is the problem
Old Mar 22, 2015 | 03:25 PM
kenworth01's Avatar
kenworth01
So if that's the problem how do you fix it ? Is it costly ?
Old Mar 22, 2015 | 04:30 PM
427 fordman's Avatar
427 fordman
If that's it most people leave it unplugged. All its for is helping the motor warm up in real cold conditions. Lots of guys up north here unplug them too.
Old Mar 22, 2015 | 05:14 PM
kenworth01's Avatar
kenworth01
So it doesn't matter to leave it unplugged dopesky hurt any thing
Old Mar 22, 2015 | 05:26 PM
427 fordman
Won't hurt anything.
Old Mar 22, 2015 | 06:23 PM
kenworth01's Avatar
kenworth01
Alright I looked into it just ended up unplugging my air temp sensor and solved the issue guess the sensor doesn't like being in the open with the new air box
Old Mar 22, 2015 | 08:27 PM
oldbird1965's Avatar
oldbird1965
Both of my trucks have the ATS in the open with no issues. I fact, without it the PCM doesn't know the air temp so it can control some functions, what I don't know.
stewart460
19
Nov 1, 2009 11:24 AM
fordorwalk
Jan 2, 2008 05:14 PM
scottie2hottie
Dec 3, 2007 11:41 AM
virgward
Dec 5, 2004 08:56 PM
good4x4
27
Jul 31, 2004 01:23 PM
