Sponsored by: Real Truck
Front hub replace?
Old Feb 20, 2015 | 08:02 PM
truck7575's Avatar
truck7575
Front hub replace?
Getting ready to do my breaks and rotors and my front right hub is shot after only 20,000 miles.. I replaced both front hubs at same time... Going with a moog unit.. The drivers side is still tight but should I replace them as a pair or wait till that hub goes out then replace? The hub is around $170 for the part.
Old Feb 22, 2015 | 11:29 AM
JNG6's Avatar
JNG6
What year truck are you working on? What issue are you experiencing? A hub assembly should last a lot longer than 20k and should be under a parts warranty still.
Old Feb 22, 2015 | 11:33 AM
truck7575's Avatar
truck7575
2003 excursion 7.3... Front passenger side hub.. It's lifted 4.5 inches and I'm running 35 x 12.5 x 20 tires and rims.. Loud drone and vibration and the tire wearing unevenly and when u jack it up you can move the tire by hand by pushing on the top and bottom.. It's clearly the hub assembly I'm afraid...
Old Feb 22, 2015 | 12:14 PM
JNG6's Avatar
JNG6
No abnormal movement in the ball joints? Popping or binding on tight turns? If not I'd agreed its probably a hub assembly issue. Lifts and larger tires seem to be pretty hard on these parts so make sure to spend the extra cash on a good brand. I used Moog and have been happy so far.
I would say wait on the driver's side it may last a long time. Unless you don't mind the extra cost or can afford your vehicle being OOS even for a day or two then do it now. Are you aware of the crazy pricing for these hub assemblies?
Old Feb 22, 2015 | 01:41 PM
truck7575's Avatar
truck7575
I'm putting a moog unit on the passenger side.. I found it for $170 ish which is a pretty good price.. I guess I'll just grease the driver side with the riff raff sensor grease attachment thingy... Maybe it will last
Old Feb 22, 2015 | 02:19 PM
JNG6's Avatar
JNG6
I just wanted to make sure you were aware the abs assembly is the same as non-abs only cheaper. Good luck with everything.....keep us posted!
Old Feb 24, 2015 | 12:37 AM
truck7575's Avatar
truck7575
When i pull the front hub off how much diff fluid will i lose in the process? Also anyone know how much when i change the rear axle seal?
Old Feb 24, 2015 | 07:05 AM
JNG6's Avatar
JNG6
I didn't have any come out on the front. Maybe a cup or so on the rear. The fluid on the rear hub seal is from inside the hub not from the diff. It is the oil bath that the bearings sit in and will need to be replaced during reassembly.
Old Feb 24, 2015 | 07:09 AM
JNG6's Avatar
JNG6
Here is a good "how to thread"
https://www.ford-trucks.com/forums/7...ake-shoes.html
245Smoke
Oct 1, 2018 11:02 AM
jlatr
Mar 3, 2016 11:36 AM
cotote
Dec 7, 2008 06:23 PM
Hoosierdaddy
Sep 6, 2005 08:26 AM
Rockwell
Feb 18, 2003 07:15 PM
