Sponsored by: Real Truck
Chirping hub
Old Feb 18, 2003 | 02:42 PM
Rockwell's Avatar
Rockwell
Chirping hub
The truck: 03 4X4 SD V10/6 speed, manual transfer case 2700miles
The symptom: left front hub chirps when in "lock" positon in both 2H and 4H. the "chirp" speeds/slows with the revolution of the wheel.
The problem/solution: Well that part is up to you guys, thats why im postin Do Tell, Do Tell.
Old Feb 18, 2003 | 04:32 PM
Fredvon4's Avatar
Fredvon4
Chirping hub
Not to be a total smart *** but if you have a competent dealer and shop, then the 03 needs an appointment, because any rpm dependent chirps, squeels, rattles, shimmy or shake are not good.
Hopefully it is as simple as a brake pad draging and squeeling a little and will go away with some age but I still would get it checked out.
None of the joints or bearings in that front end should ever make any noise.
Old Feb 18, 2003 | 05:11 PM
Munkey's Avatar
Munkey
Chirping hub
Mine truck does this every now and then...I just unlock and lock them back, no more chrip! Anyone have any further insight into this??
Old Feb 18, 2003 | 05:36 PM
HD Power's Avatar
HD Power
Chirping hub
Mine did that once as well as a high pitch screeching noise, but i ran the truck in four wheel drive several times and it finally went away...
Old Feb 18, 2003 | 07:15 PM
Rockwell's Avatar
Rockwell
Chirping hub
I wouldnt take your comment as being a smart @ss in any way, youre trying to help. This chirp however is not "rpm dependent", it is "wheel revolution dependent", and only occurs when the hub is in the lock position, regardless of the transfer case position. In other words, I could literally push the clutch in, shut the motor down, and the chirp would still exist so long as the wheel is still spinning. If I change the position of the hub from lock to "free" theres no more chirp.
ON EDIT: Fredvon4...now i see what you are saying, when you say "rpm dependent" you are meaning the rpm of the wheel. Got Ya!
