Sponsored by: Real Truck
HUB Grinding
Old Sep 2, 2005 | 09:40 AM
Hoosierdaddy's Avatar
Hoosierdaddy
HUB Grinding
2000 F250 4x4 CC
Starting yesterday, my passenger side front ESOF hub is intermitantly grinding. Vehicle speed does not matter and it does it going straight as well as when turning. Only periodically. When it hangs up while driving, I can feel the truck pull to the right and it makes a terrible grinding noise, kind of like brake rotors grinding. Brakes are almost new and the hub is hot, so I've narrowed it down to the hub.
My question is-Is fixing this as simple as swapping out the outer hub with Warn premiums or is there something else wrong????? Where is the best place to buy Warns????? How much $????
Thanks.
-Steve
Old Sep 2, 2005 | 01:15 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Unfortunately, you're looking at a very costly replacement of the front unit-hub bearing assembly. While easier to install on the assembly line, when it comes time to replace parts, the customer really takes it hard. You're looking at approximately $500 to get just the bearing assembly. If you can install it yourself, then you save a ton of labor cost, too. Warn locking hubs will not fix the problem, nor will any fit.
Sorry to be the bearer of bad news.
Cody
Old Sep 2, 2005 | 02:08 PM
Hoosierdaddy
Assuming this is the hub main bearing-"the unservicable one" and I need to replace the entire hub assembly, do I need to remove the knuckle to replace the hub assembly or can I leave the knuckle and ball joints alone and just unbolt the hub assembly in place??? I replaced the BJ's and inner seals last winter. I hate to pop the BJ's-that would really suck!
Thanks.
-Steve
Old Sep 2, 2005 | 03:07 PM
vwp6269's Avatar
vwp6269
You dont have to mess with that. Just unbolt the assembly.
Old Sep 2, 2005 | 03:17 PM
Hoosierdaddy
Good. I'll rip into it this weekend.
http://www.trademotion.com/partlocat...00&catalogid=1
Old Sep 2, 2005 | 03:35 PM
Darrell 1's Avatar
Darrell 1
https://www.ford-trucks.com/forums/s...&highlight=Hub
I recently used (last week) the description put together by Racerguy above. Very useful in showing me what I was getting into. I did destroy two studs getting the hub out as it was rusted in there pretty good for a 2000 F250. Also the seal came out in two pieces. I could not find an aftermarket hub bearing so I paid about $ 630 Can through Ford. Ouch!
D
Old Sep 3, 2005 | 11:00 AM
Ed Willmott's Avatar
Ed Willmott
I found this thread in a searh because I have to replace the same thing - Not happy at all. I just need $40 worth of bearings and races but Napa has the assembly for $380eaMy question is do I need to do both sides? Man, I hope not!
Old Sep 6, 2005 | 08:26 AM
vwp6269's Avatar
vwp6269
You dont have to do both sides. However most people usually do. If one side failed the other side is probably soon to follow.
