Duallys Only
Old Oct 1, 2019 | 08:45 AM
  #2041
17 Oaks's Avatar
17 Oaks
2011 F 350 Dually, Arctic Fox 1150, pulling trailer 10,000 lbs. Total weight tow/payload was just over 15,000 lbs. Stable Load uppers, Rancho 9000XL shocks only mods I had, later I added the Big Wig sway bar. It sits level and rode good on that 1500 mi trip, still got about 11 mpg.
Custom built an extension to mate with a trailer, no sure how long the ext is.
I never folded, so anyone wanna take a guess as to why the other duallies did?
Old Oct 1, 2019 | 10:10 PM
  #2042
EO2SeaBee's Avatar
EO2SeaBee
The interesting thing to me about the folded frames is that the most weight the frame would have had to support would have been from the point of the failure (front hanger for the rear springs), to the front bumper - or basically the same as if he was riding a wheelie. If it was THAT heavy, he would have known the instant he attempted forward motion and the front end came off of the ground. At the very least, he wouldn't have had any steering to speak of - even if he wasn't riding a wheelie. Something just doesn't seem right to me. I'm guessing something other than weight damaged the frame prior.
Old Oct 3, 2019 | 10:59 PM
  #2043
MTalley's Avatar
MTalley
Did someone mention duallies? Our third F-350 DRW (previous ones were 2002 and 2013).
Old Oct 4, 2019 | 06:23 AM
  #2044
troverman's Avatar
troverman
Originally Posted by Y2KW57
WHOA.....Stop the presses. It happened AGAIN?
Check this photo out:
Exact same situation. Same Okanagan truck camper. Same utility trailer.
But DIFFERENT Ford dually truck. The photo up top shows an ALL WHITE monochromatic crew cab dually.
And the photo below shows a TWO TONE crew cab dually with a bottom tan accent color.
And before accusing finesse with photoshop, note that the top photo is an F-450 with 19.5" wheels and tires, while the bottom photo is of an F-350 with 16" wheels and tires.
The background surroundings are significantly different as well.
But the Ford frames are not. In this era, the Ford frame between an F-350 and an F-450 pickup are the same, especially in the area of failure.
Given the extreme improbability that two different people would have the EXACT same utility trailer (notice the unique aspects of that utility trailer... roadside man door, dark colored pressure equalization vent, unusual trailer tongue ground effects skirting) combined with the exact same Okanagan truck camper (notice the mirrored window tinting, the double vented refrigerator, the decal color and location, the same camper jacks, and the same metal trim under the roadside compartment at the tailgate)... what we have here appears to be an expensive lesson that didn't get learned the first time.
What is it called when a person repeats the same thing, expecting different results?
Perhaps he thought he was "upgrading" with the F-450 over the previous F-350. But that upgrade only involved brakes and axles... not the frame. Clearly, something wasn't working with his load. I suspect excessive weight aft of axle.
Does anyone know more about this fella and his repeated catastrophe?
Actually, the 350 in the picture has 17" wheels, small correction.
Does Ford authorize this type of towing? To me, that 2-3' long tow bar extension coupled with an enclosed, fairly heavy tongue weight trailer is going to wreak havoc on any frame. The truck camper alone nearly maxes out payload, even on the F-450. Go over some bumps at speed and it's like having a leverage bar against your frame.
EDIT - why isn't there diesel spilling out at least under the 450? With that angle, I'd be fairly certain the fuel lines would break.
Old Oct 4, 2019 | 06:46 PM
  #2045
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Is the radius arm bent?
Have you taken any photos of the damage underneath that you care to share?
I've often wondered if the Super Duty could benefit from the triangles that Ford mounted to the frame of the F-150 to prevent front tire encroachment into the cab foot well in offset head on collisions such as what you just experienced.
Radius arm took the brunt of the force. Haven’t put it on hoist yet. But parts from what I saw. Bumper, fender, headlight assembly, radius arm , tie rod plus whatever else they find.
Old Oct 4, 2019 | 10:38 PM
  #2046
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
This is exactly what I suspected, and why I inquired about the radius arm. Many thanks to you for posting a photo of the failure modality, as it confirms my long held suspicions about those radius arms in angular or offset collisions.
Old Oct 5, 2019 | 08:14 AM
  #2047
bigredtruckmi
Veteran: Navy
glad to help. Enjoy the weekend.
Old Oct 5, 2019 | 07:48 PM
  #2048
Ferguson65's Avatar
Ferguson65
Still love my 6 year old wide hipped girl!
Old Oct 5, 2019 | 08:00 PM
  #2049
schlepprock250's Avatar
schlepprock250
I posted on a different thread, but since this is a dually thread I'm in.
Old Oct 5, 2019 | 09:53 PM
  #2050
scraprat's Avatar
scraprat
Top Answer: 5
Good looking dually
Old Oct 6, 2019 | 09:23 PM
  #2051
bigredtruckmi
Veteran: Navy
Nice! Rig.....
Old Oct 8, 2019 | 08:43 AM
  #2052
machmedic's Avatar
machmedic
Ferguson65 love the Green Gem!
Old Oct 8, 2019 | 08:45 PM
  #2053
Ferguson65's Avatar
Ferguson65
Thanks! I've loved the color since I saw the first 11 pop up on the lot. Knew I had to have it when I ordered 13. When its shined up and in the sun there's nothing like it!
Old Oct 8, 2019 | 08:56 PM
  #2054
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Old Oct 14, 2019 | 10:50 AM
  #2055
golfmedik's Avatar
golfmedik
I still love this truck. She is now over 6 years old and just rolled over 40k miles...
