Duallys Only
Old Nov 23, 2016 | 03:28 PM
  #1816
senix's Avatar
senix
That Ice Tea in the pic is for the Mrs. But given the chance I am sure he'd like a sip.
Old Nov 23, 2016 | 10:31 PM
  #1817
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Nice Scott.........
Doggies are the best......
Old Nov 23, 2016 | 10:32 PM
  #1818
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Originally Posted by ZooDad
Roy,
Our Costco had one of their Roadshows and I got the smaller one for the house. Then the wife noticed the "portable one" even included a carrying case and small inverter. With all the fire restrictions in the California mountains now, BBQ was starting to be a pain.
So I now have this one onboard the trailer. I have used it several times it works great. I have not tried to run it off the inverter yet though.
Here is some info on it.
Traeger Portable Grill
Amazon Info
Keith
What is your opion of this vs charcoal..........??
Old Dec 24, 2016 | 03:38 PM
  #1819
PlayersZ28's Avatar
PlayersZ28
Well, was going to just replace the pads on my truck @ 65000mi as the rotors didn't look too bad but it looks like I need more than that. Left rear has a seized slider pin and right rear had a broken piston. I haven't taken the fronts apart yet.
Anyone had the full brakes done at the dealer so I have an idea of cost? Was hoping to head south on Tuesday but that will get delayed now depending on how long it takes to get parts and whether I just have the dealer do the work.
Old Dec 24, 2016 | 04:02 PM
  #1820
porthole's Avatar
porthole
My local Advance auto had pads rotors and calipers in stock when I needed them.
I ordered online to get the discount that usually pops up on the website then picked up at the store.
Old Dec 24, 2016 | 04:50 PM
  #1821
PlayersZ28's Avatar
PlayersZ28
I can get the parts from local Napa (I'm in Canada) I expect but rather than mess around and take more time I think I'll get the dealer to do it, my son gets 1/2 normal shop rate.
How hard is it to do the rear rotors on the dually? Haven't looked at how the fronts are mounted yet either.
Old Dec 24, 2016 | 07:10 PM
  #1822
porthole's Avatar
porthole
You need a special socket for the rear hub bearing nut. May be called a hub nut or spindle nut socket. Also got that at Advance for under $20.00
Take axle out, remove caliper and bracket, take hub nut and bearing out, remove hub and rotor, unbolt rotor from the inside.
Fronts
Look at this page to see what the fronts look like. Use a socket and extension through the hole in the wheel adapter.
Leave the nuts on with a couple of threads. If you have a big enough wheel puller for a slide hammer, have at it. Or carefully with a maul, have at it.
Odds are good the rotor will need to be hammered off as well.
https://www.ford-trucks.com/forums/1...l#post13764203
Old Dec 25, 2016 | 07:05 AM
  #1823
senix's Avatar
senix
don't forget some extra axle lube when you take the axles out.
If you were just doing calipers and pads not so bad.
Old Dec 25, 2016 | 08:42 AM
  #1824
PlayersZ28's Avatar
PlayersZ28
My son says his shop has an on truck rotor turning machine so if the rotors can be cut I can avoid replacing them until next summer when I have the time to do it. You referring to diff lube?
Old Dec 25, 2016 | 05:34 PM
  #1825
senix's Avatar
senix
yeah diff lube. Those on the truck machines for the rotors are sweet. Didn't have those when I was turning wrenches.
Old Jan 4, 2017 | 10:27 AM
  #1826
MDSuperDuty's Avatar
MDSuperDuty
Here is my thread when I did my rear brakes. I know I wasn't as precise taking pictures but hopefully this can help somewhat.
https://www.ford-trucks.com/forums/1...-included.html
Old Jan 4, 2017 | 11:57 AM
  #1827
porthole's Avatar
porthole
Just looked over your thread, why the concern with re-packing the bearings?
truck rotor turning machine ...... rotors can be cut
That machine is 'cutting' or 'grinding' the rotors?
Old Jan 4, 2017 | 12:39 PM
  #1828
MDSuperDuty
I believe I cleaned them real good to get a look at them so they needed it and from what I would imagine the manual that I read was saying to do so.
Old Jan 4, 2017 | 02:21 PM
  #1829
porthole's Avatar
porthole
Oil bath from the differential
Old Jan 4, 2017 | 02:54 PM
  #1830
MDSuperDuty
Then the manual I had was misinformed then. haha. Seriously I took it from a manual...
