My 63 Build!
Old Jun 30, 2015 | 09:54 PM
  #106
jlincks's Avatar
jlincks
Once more got a little done. Drivers side fender is mocked up. Bolt are in it but not tight. Have to wiggle things around to make it all line up. Fender wells are out and it is setting as low as it'll go. It's a little uneven from the passenger side to the drivers. The passenger is about 3" and the drivers is about 4 1/4" to 4 1/2". I'm not sure what's holding up the drivers side but I'm going to investigate a little bit. Could be something simple.
Old Jun 30, 2015 | 09:56 PM
  #107
Jeff Ranger's Avatar
Jeff Ranger
looks good though
Old Jul 2, 2015 | 10:18 AM
  #108
red66rider's Avatar
red66rider
Nice build so far... im looking to bag my 66 just not sure when though... trying to tackle man to auto swap first
Old Jul 5, 2015 | 12:45 PM
  #109
jlincks's Avatar
jlincks
Thanks. ^^
Got the rear bags and brackets in now.
Old Jul 5, 2015 | 04:01 PM
  #110
red66rider's Avatar
red66rider
Is the rear just going to be a two link?
Old Jul 5, 2015 | 05:04 PM
  #111
jlincks's Avatar
jlincks
It's a parallel 4 link. I've still got to a panhard bar for it to keep the rear centered.
More progress though. Got the bed put on.
Old Jul 5, 2015 | 05:15 PM
  #112
ap67et10's Avatar
ap67et10
Good looking truck! Real nice seeing the "right" bed on it. Keep up the good work!
Andrew
Old Jul 5, 2015 | 05:19 PM
  #113
red66rider's Avatar
red66rider
Looks good with the bed on....
Ever figure out the issue on the front laying uneven?
Old Jul 5, 2015 | 07:44 PM
  #114
jlincks's Avatar
jlincks
I still haven't figured it out. I'm going to pull the bags and brackets off the front and drop it with out them and see what it does.
Old Jul 6, 2015 | 07:07 AM
  #115
Jeff Ranger
Very cool, before long youll be ready for paint.
With the bed, if i remember correctly they used wood spacers. That should get your line even and ive heard a lot of guy buy hockey pucks and cut them for spacers. Im planning on tyring this as my bed doesnt line up
Im cheap so i like when i find stuff that works. So whenever you get ready to choose paint....
Check this out....About $160 for a full kit on a lot of them. Now im doing mattes, low gloss and stuff like that but in comparison to hotrodflatz its like 60% cheaper and seems to be the same
http://shop.thecoatingstore.com/
Old Jul 6, 2015 | 01:23 PM
  #116
jlincks's Avatar
jlincks
You forgot to put the link Jeff. Talking about making things work with what you have. I used a metal u shaped fence post as the new front support for the bed since the old one was rusted out. I will have to shim it about half an inch to make it all line up.
Old Jul 6, 2015 | 01:29 PM
  #117
Jeff Ranger
Yeah, I am always looking for stuff to work in to fill gaps and such so i know way mean..added the link to the previous post
Old Jul 12, 2015 | 04:23 PM
  #118
jlincks's Avatar
jlincks
Got my panhard bar put i today. Made a couple brackets and bolted it in. I used a adjustable top link for a tractor as my panhard bar. There's about an inch of space between the pumpkin and the bar. I've seen people use stuff like that in jeeps and 4x4 vehicles so I figured why not. It was only $21 from tractor supply. Also you can see in the picture where I'm going to use the old engine support bar to replace the existing frame support that's in the way of the driveshaft.
Old Jul 12, 2015 | 06:59 PM
  #119
TxStang2010's Avatar
TxStang2010
if they can support the weight of a 10 foot rotary cutter I'm sure they can handle being a pan hard bar
Old Jul 12, 2015 | 07:51 PM
  #120
jlincks's Avatar
jlincks
^^ that's kinda what I was thinking.
