inline fuel pump?
Old Feb 1, 2015 | 12:21 AM
ruschracing4's Avatar
ruschracing4
inline fuel pump?
So I traded a chevy 1500 that I bought for 450 for this ford f250 7.3L powerstroke that hadn't run for a couple of years because of a fuel leak. So I found the leak fixed it installed a new mechanical pump behind d the fuel bowl and can't get it to draw any fuel. So I dropped both fuel tanks rear tank had a leak and front tank had a bad sending unit/pick up line. Would it be OK if I put a low pressure pump in the fuel line? It's supposed to draw fuel with no pump in the tank and I already ordered a inline pump just wanna check if this will hurt anything.
Thanks
Old Feb 1, 2015 | 12:34 AM
stainlessstroker95's Avatar
stainlessstroker95
You shouldn't need a in line pump before the mechanical pump. So are you saying that you replaced the pump and it is not filling the fuel bowl. It may take a little bit cranking to get fuel up there after the fuel tank work and all.
Old Feb 1, 2015 | 07:34 AM
ruschracing4
I wasn't going to put it right before the mechanical pump I was going to put it down by the tank to make beading air less of a pain in the butt
Old Feb 1, 2015 | 08:10 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Honestly I don't think I'd waste money on a lp pump. I think you would be best off getting it running then go full efuel if all is good.
Old Feb 1, 2015 | 08:13 AM
ruschracing4
That costs a lot way to much I have the in line pump for 25 dollars. I just want to know if it is a good way to bleed out the air.
Old Feb 1, 2015 | 08:32 AM
fordman67's Avatar
fordman67
It won't help.you wasted 25$
Old Feb 1, 2015 | 08:57 AM
ruschracing4
really dude you have to be the annoying mother in law almost telling me what I should or shouldn't spend money on? With it help bleed air out or not!!!!!
Old Feb 1, 2015 | 09:28 AM
ReBilld's Avatar
ReBilld
Shouldn't need the electric pump to bleed air. Just fill the bowl and crank the engine. It should be fine.
Old Feb 1, 2015 | 10:32 AM
fordman67's Avatar
fordman67
Where will the air go then? If the mech pump isn't pumping the air can't go anywhere! And on top of that the regulator doesn't allow return fuel flow until 50-55 psi.your inline pump would be lucky to achieve 12psi .
Its just not the way to make it run again.no smart comments needed.
Old Feb 1, 2015 | 11:07 AM
MOOSE_MACHINE
Ok ok simmer down people. IMO the electric pump may help to prime the mechanical pump. But the design of these pumps allows them to prime themselves easy enough. But here's the kicker on your $25 pump, if the pump does not pump enough fuel to keep up to the mechanical one it will cause restriction wearing the mechanical one out prematurely, also, if the electric pump dies It may cause enough restriction to keep the truck from running properly. IMO the cons out weigh the pros. But that's just my opinion. Take it or leave it, makes no difference to me.
Old Feb 1, 2015 | 12:09 PM
fordman67's Avatar
fordman67
Its just that the inline pump at 25$ is most likely a low pressure carb type system . the factory pump can make 70 psi or more depending on the regulator spring pressure. The stock pump pumps from tank to pump and out at a lower pressure.then to filter.from filter back to pump.then the high pressure side ships fuel to banjo bolt and to the heads. From heads to regulator across the return to tank.
If the pump can't get air/fuel past the check valves in the pump and overcome the regulator then no bleeding or purging is going to happen.
Fill the filter housing.then the high pressure side of the fuel pump is gravity fed and only has to move fuel 8-10" to the heads and tada magic is made.
My original response was not meant smart Alec. I was in a hurry from other factors at home and just hate to see people waste time and money.
For the most part we ARE all friends here. Have a great Sunday!
Old Feb 1, 2015 | 09:53 PM
rustybottoms88's Avatar
rustybottoms88
This makes sense. Put the lp pump on ur lawn mower or something.
Old Mar 8, 2015 | 05:04 PM
Airstreamer67's Avatar
Airstreamer67
I put an auxiliary low pressure fuel pump in line because I wanted to add two water/sediment fuel filters to my system. I knew the two extra fuel filters would put an additional load on the engine fuel pump trying to suction fuel through them. The auxiliary pump pushes the fuel through the two added filters at about 4 psi. Should this Kennedy pump ever fail, it is deigned to provide no additional restriction to drawing fuel through it. So, with my setup, I have super-filtered fuel to the engine without overtaxing the engine fuel pump. I also have fuel pressure gauges to let me know what's going on. It cost a few bucks, but I don't want to get caught on the road with fuel contamination problems.
ohiofordnut
May 23, 2009 03:12 PM
tony b
Nov 4, 2006 10:10 AM
moose94
33
Jun 30, 2005 12:03 AM
Longbed 68
Jan 20, 2004 06:48 PM
dbarracuda
Oct 24, 2002 11:31 AM
