Fuel pump
Old May 23, 2009 | 12:33 PM
ohiofordnut's Avatar
ohiofordnut
Fuel pump
Hi i got a new fuel tank giving to me for a 93 f150 with the fuel pump inside inside the tank
if i hooked the fuel line up from my 78 to it would my fuel pump on the engine be able to suck the fuel thru the fuel pump in the tank if not what would i have to do
thanks john
Old May 23, 2009 | 01:25 PM
montana_highboy's Avatar
montana_highboy
I'd just do away with the electric pump and use your mechanical pump like you would with any other tank on these trucks.
Old May 23, 2009 | 01:45 PM
ohiofordnut
Fuel pump
If i did away with the fuel pump in the tank how would i use the gas gauge then . but i just hooked the 78 fuel line to the fuel pump in the tank and it wont start .it has a new mechanical fuel pump on the truck and a new line .then i put the hose in a gas can and it starts right up but hook it up to the gas tank with the fuel pump in the tank and it wont start
Old May 23, 2009 | 02:17 PM
scrapyardking's Avatar
scrapyardking
i dont believe it will flow thru that electric pump. Why dont you keep that sending unit in so you can use the gauge then drill another hole and use a bulkhead fitting to run the fuel line in.
Old May 23, 2009 | 03:12 PM
ohiofordnut
Fuel Pump
Well i fixed it i took the fuel pump out of the housing in the tank put in a piece of 5/16 in its place and put the desending unit back on the pump housing and works like new thanks for the help
