IH Waterpump
Old Jan 26, 2015 | 11:18 PM
bakerbuilttracks's Avatar
bakerbuilttracks
IH Waterpump
Hey all
wondering how the IH Waterpumps are holding up for those who are running them. Looking to order the kit from diesel site this week and want to be absolutely positive they hold up good and last.
I have had major bad luck with auto parts stores water pumps. something like 5 pumps in the past couple years and 2 this year alone. Heres a link to the thread on my issues https://www.ford-trucks.com/forums/1...-pump-4-a.html.
Don't know why they keep leaking out of the weep hole other than just very poor quality parts.
Im so tired of replacing them and want a one and done solution. So are they worth the investment ?
Old Jan 27, 2015 | 07:48 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Exactly how much coolant have you been actually losing out of your weep holes?
Is a little weeping sufficient cause for change?
Old Jan 27, 2015 | 08:16 AM
Walleye Hunter's Avatar
Walleye Hunter
For me it would be. Small leak wouldn't get fixed in the dead of winter but once it warmed up a bit I'd fix it. For some reason I'm OK with a little oil drip but I like to keep my water contained.
Old Jan 27, 2015 | 10:55 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Replaced my bad OEM water pump with the IH one from Diesel Site and it has been flawless so far. The build quality is drastically different on the IH.
I have only had mine on for about 500 miles though because the truck is not a daily driver for me.
Also, because of my comments in your other thread you already know my thoughts on the IH pump.
renoduckman
Mar 15, 2018 11:38 AM
87f-150stepside
Jan 18, 2013 06:48 AM
rmilchman
Nov 23, 2009 01:27 PM
wheressinatra
Oct 16, 2006 05:28 PM
avidbow
16
Aug 11, 2006 04:08 PM
