which water pump
Old Mar 5, 2018 | 04:59 PM
renoduckman's Avatar
renoduckman
which water pump
Its time for the water pump to be replaced on my 02.
Should I get an OEM one? Is there a better brand to buy, or is one from an auto parts store ok?
I appreciate the input.
Old Mar 5, 2018 | 05:00 PM
268Fords's Avatar
268Fords
Riffraff diesel.
Old Mar 5, 2018 | 05:13 PM
duck fan's Avatar
duck fan
Because racetruck
Used a few from Riffraff Diesel over the years. I think one of the earliest has been on for almost 6 years now.
Water Pump OEM 7.3L (RDP-8501)
Old Mar 5, 2018 | 05:19 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
RiffRaff for OEM or Diesel Site for International version. Done...
CousinCarl's Avatar
CousinCarl
I was in a pinch when I had to do mine and have one from the Irish store on there. I originally went with an OEM reman but it leaked like a sieve. Had to do it twice. If you have the luxury of waiting for shipping, I second the Riff Raff pump.
Old Mar 5, 2018 | 05:22 PM
CousinCarl's Avatar
CousinCarl
Grab Clay's billet t stat housing, too. It's worth it. Stripped bolts and/or fighting to get that thin factory aluminum to seal evenly, even with RTV, can be a headache.
Would also be a good time for the upper rad hose that routes around the serpentine belt.
Old Mar 5, 2018 | 06:06 PM
Skydivelout's Avatar
Skydivelout
Riff Raff and everything CousinCarl said.
Old Mar 5, 2018 | 06:25 PM
AllaboutMPG's Avatar
AllaboutMPG
If you want to go with a filter for your coolant system you can do this
Bus Parts, International, Powerstroke, Ford
Nicmike did a pretty good write up on the install and parts. It's a bit more work but your cooling system will be filtered. You can buy the complete kit from dieselsite but it's $400+. Piece it yourself and it's just over $200
Edit: link to write up. Starts around page 3
https://www.ford-trucks.com/forums/1...er-pump-3.html
Old Mar 5, 2018 | 07:29 PM
MiamiPSD's Avatar
MiamiPSD
i think Riffraft is Navistar...not motorcraft.
Old Mar 5, 2018 | 09:13 PM
crop harvester's Avatar
crop harvester
That was what I got from clay [Navistar]
Old Mar 5, 2018 | 10:56 PM
timmyboy76's Avatar
timmyboy76
7yrs/175k...Airtek from Rockauto..but think, the coolant filter has alot to do with longevity
Old Mar 9, 2018 | 05:24 PM
CarterKraft's Avatar
CarterKraft
I just put the Motorcraft on, made in China if it matters to anyone.
Old Mar 11, 2018 | 09:40 PM
Firefighter 1406's Avatar
Firefighter 1406
Did the same on mine. Also have a coolant filter and it’s been on there for at least 60,000 miles.
Old Mar 12, 2018 | 08:56 AM
andym's Avatar
andym
I have the Sinister Diesel coolant kit. It was $139 and has a billet aluminum head. It looks really sharp too. I don't have a picture of it, and it's raining right now otherwise I would show you.
https://sinisterdiesel.com/i-1588343...ategory:954835
Riff Raff Diesel sells plenty of Motorcraft parts.
Old Mar 15, 2018 | 11:38 AM
renoduckman
Thanks for the input will go with Riff Faff. I have bought some filters before from them.
Joe
Texas Bob
Jan 24, 2020 11:37 AM
Auzzie f250,7.3
Apr 10, 2011 01:06 AM
lunchboxchoch
1997 - 2003 F150
Mar 13, 2011 08:24 AM
Phillip Martinez
Feb 20, 2011 07:57 PM
2danglong
General Diesel Discussion
Jun 1, 2009 09:01 PM
