unknown engine need help
Old Jan 1, 2015 | 11:27 PM
repsolla's Avatar
repsolla
Yea I was just being lazy and was tired of working in the dark. I'll pull the rods and Pistons out tomorrow. Just weird that I can't figure out what motor this is
Old Jan 2, 2015 | 08:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
i had the same issue with a 66 289 a few years ago.
one piston was stuck.
it took about 15 hard hits with a 5 lb sledge on a 2X4 to the bottom of the piston to break it free.
Old Jan 2, 2015 | 02:20 PM
85e150's Avatar
85e150
[QUOTE=tjc transport;14958507]i had the same issue with a 66 289 a few years ago.
it took about 15 hard hits with a 5 lb sledge on a 2X4 to the bottom of the piston to break it free.[/QUOTE
x8, I had a '66 289 that had been put together without the block to head dowel pins. All 8 were rusted in. Pounded them out, then had to sell the car as a basket case. I made $100 in the end..... A little rust goes a long ways in the cylinder.
Old Jan 2, 2015 | 02:56 PM
repsolla's Avatar
repsolla
Yea I didn't think about that. I first looked for broken parts that might have been jammed between the crank and something. Pulled apart a 351 that had the same problem. I guess when I get home tonight I will tear it apart all the way. But how come I can't find some parts for this motor. Like the valve springs. And timing cover
Old Jan 2, 2015 | 04:32 PM
85e150's Avatar
85e150
Valve springs are readily available, try NAPA or aftermarket. Cam makers sell kits with valve springs.
Front cover might be a jy item, but I turned up a couple with a search, so they are available also. Billions served......
Also, the FE top end oiling requires the bolts holding the rocker shaft on be placed in the correct holes as one serves as an oil passage. Get a book on these and/or make sure you keep everything in order when working on the heads etc.
Old Jan 2, 2015 | 04:55 PM
repsolla's Avatar
repsolla
I was looking at summit racing and couldn't find things like after market cranks. Valve springs. Heads. Very few Pistons. Very few rods. And no timing chain covers. And yes I selected the right motor.
Old Jan 2, 2015 | 05:37 PM
tjc transport
i ain't rite
if i remember correctly all FE timing covers are the same, through all engine sizes.
FT is a different animal though. you have to be careful, FE and FT parts do not readily mix.
Kurt G.
Oct 1, 2016 01:02 PM
larry69chevelle
Nov 8, 2010 09:49 AM
junkyarddog82
Aug 25, 2009 01:53 PM
oldtrapper
Jul 12, 2005 08:42 PM
ladyrebecca
13
May 15, 2004 09:30 PM
