engine I.D.
Old Nov 6, 2010 | 11:31 PM
larry69chevelle's Avatar
larry69chevelle
engine I.D.
I just purchase a converted chevy truck with what I was told a Ford F250 four wheel drive frame and running gear. I was told the motor is a 460 big block Ford. Every time I show someone the engine, the response I get is BIG-EYES and if I want to sell the motor or the entire truck. SO, I wander what is up with the engine. You can tell that it is an old motor. Under all the grease and dirt I can see Cobra LeMans on the valve covers. So here is my question is;" Where is the I.D. numbers or special marks or castings on the marks?"
Old Nov 7, 2010 | 08:00 PM
LxMan1's Avatar
LxMan1
I'm thinking 427 or 428. No Cobra LeMans 385 series engines that I'm aware of. I moved this to the FE forum to see if these guys can help.
Old Nov 7, 2010 | 09:49 PM
85e150's Avatar
85e150
Searching for valve covers, I find "Cobra Le Mans" units for FE motors, and maybe small blocks--Ford did run 289s at Le Mans after all.
I also find adaptors to put FE covers on Windsor motors:
Windsor Valve Covers
And 385 series covers that say "cobra".
The easiest way to tell if your engine is an FE is to look at the intake manifold. If it is covered by the Valve cover, it is an FE.
Pics and other tips here:
http://www.crankshaftcoalition.com/w...tify_a_Ford_V8
Casting number info here:
ford engine casting numbers,head casting numbers,crankshaft casting numbers picture locations
ford head casting numbers,crankshaft casting numbers picture locations
(scroll up on that one for the FE head pic)
Decoding Ford casting part numbers
Old Nov 8, 2010 | 05:19 AM
jowilker's Avatar
jowilker
Larry, Some photos would help, I don't how to look at a FE and tell if it's a 428 or 352. Can you load or link some photos of the setup.
You may also be showing it to other chevy guys that don't have a clue.
John
Old Nov 8, 2010 | 09:49 AM
maxtor's Avatar
maxtor
No matter what it is, if you replace your chevy with that Ford, you will go faster...
