2014 F350 upfitter switch wire location.
Received 3,118 Likes
on
The Upfitter wires are located on the driver's side under the dash close to the firewall. They are prewired to the switches and fused.
see page 4 of this bulletin to help you locate them
https://www.fleet.ford.com/truckbbas...tml/Q180R4.pdf
on
As I read the Ford bulletin and see pictures of the 3 parts needed to install the switches, so, the simple answer is no.
You have one connector to plug the upfitter harness into the truck wiring (assumes this connector is the power from the underhood Power Distribution Box) and then you snake a wiring harness over to where you mount the relays. See above eBay link and associated part numbers.
If no switches, you need all 3 parts.
elinmon1976
12-22-2009 03:20 PM
