stroking out a 352 block
Old Dec 2, 2014 | 02:58 PM
fluidp's Avatar
fluidp
Hi. Im currently looking at some options for my 66 f100. It has a 352 and I am wondering about boring the block to 4.050 (standard 390 bore) and installing a Scat rotating assembly. what is the max stroke I can go with?
I don't mind doing a few tricky mods if required.
Thanks
Old Dec 3, 2014 | 12:06 AM
85e150's Avatar
85e150
If your block will go .050 over, you can go as far as you like. The Scat folks or Survival will have all the block clearance info.
With a 4.050 bore, you would end up about 438 with a 4.25 stroke, the largest I found in my 30 seconds of checking.
Old Dec 3, 2014 | 09:55 PM
rockittsled's Avatar
rockittsled
Do the drill bit test and if it looks good then do a sonic check on the cylinder walls to find out the actual cyl. wall thickness
https://www.ford-trucks.com/forums/6...st-rehash.html
Good Luck ... core shift is a problem and may show up
Old Dec 5, 2014 | 08:45 PM
PA74F250's Avatar
PA74F250
I'd be willing to be you can't go that big on a 352 block. I would suggest looking for a 360/390 block that hadn't been bored yet. Besides I think there's some problems with your plans. I'm pretty sure you can't use a a stock 390 piston with a 4.25" crank. I think the pin location is a little different for the stroker combo. I think Survival only offers a 4.080 or 4.090 piston. If I am right which I think I am on the piston choice means you would really have to make your block big.
The last stock 352 block I had was sonic tested and wouldn't do a 4.050 bore.
I did actually order a 445 kit from Survival like 2 months ago and have yet to see a piece of it so I can't give you any insight on that stuff or at least yet.
Old Dec 14, 2014 | 03:34 PM
1972RedNeck's Avatar
1972RedNeck
If I was going to spend the money, I would get the 4.375" stroke. Why wouldn't one get the biggest? It's not going to cost much, if any, more than stroking it 4.25".
I definitely wouldn't spend the money on a 410, or in my case, 416.
free59mod
15
Feb 4, 2017 04:11 PM
Nick-1973-ford
Sep 7, 2016 06:33 PM
MartyRayII
Feb 18, 2011 07:17 PM
shephard199
Mar 6, 2009 02:05 PM
skonnie-mark
Aug 26, 2004 11:37 AM
