Drill bit test rehash
Old Sep 23, 2007 | 06:49 PM
hoxiii's Avatar
hoxiii
Allright, I have my 390 more or less torn torn so I figured while I had it apart i'd do the drill bit test just to see what I was working with. I got myself some measurements, but then was presented with an issue.
I searched for the drill bit test on this forum, but all of the posts i found said "do a search for drill bit test, it's on here somewhere".
So I have a set of numbers, but nothing to compare them with.
So first off, I would like to request that the "drill bit test" measurements be added to the FE FAQ and secondly could someone just tell me what my numbers mean?
I pulled out an assortment of drill bits and allen wrenches to do my test to find out what the best fot was. The biggest one that would fit anywhere wound up being a 3/16 allen key across opposite points. It measures to .2165" which is bigger than 13/64 of an inch but smaller than 7/32.
Justin
Old Sep 23, 2007 | 07:54 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Drill bit test is Dave Shoes invention. 64ths are use as a universal measurements.
352, 360, 390, 410 blocks use a 16 to 17/64" drill bit shank.
428 and some 361,391 and 406 blocks 13 to 14/64" bit shank.
Some 406 (with 427 wall cores) and most 427's a 8/64" bit shank.
While it's a good field test it still needs to be conclusive with an accurate sonic map. The drill bit test just tells you what cyl wall cores the block was cast with. Not how thick they are. But still a nice thing to know when block shopping.
I'd also seek Dave's permission and credit him in the writeup if this was to become a fixture in the FAQ section. He's a good guy and deserves the credit due.
Old Sep 23, 2007 | 08:02 PM
hoxiii's Avatar
hoxiii
so i have the 428/406 cores. nifty.
And i know it's not 100% accurate, but what's the sense in even getting the block sonic mapped for 428 bores if it's a plain 390 block.
Justin
Old Sep 23, 2007 | 10:06 PM
masterbeavis's Avatar
masterbeavis
I am stupid, what are the drill bits supposed to show you, er where to use them to check?
Old Sep 23, 2007 | 10:35 PM
390cobrajet's Avatar
390cobrajet
well, because if the walls check out thick enough then you can bore that block many times, which is nice. or you could just bore it over enough to get the 410-428 bore.
Old Sep 23, 2007 | 10:37 PM
masterbeavis
I still don't follow where the drill bits come into play?
Old Sep 23, 2007 | 10:57 PM
390cobrajet
well, if you pop out the center freeze plug on either side, then you can place the drill bit shank in between the cylinder walls of the center two. you use the bit as a gauge, asuming the cylinders are all located the same, which they should be, then you can tell if the block was cast with thicker walls.
Old Sep 23, 2007 | 11:16 PM
hoxiii's Avatar
hoxiii
The smaller the drill bit that you can fit between the cylinder walls, the thicker the walls are and the more overbore it ::SHOULD:: be able to take.
Justin
Old Sep 24, 2007 | 12:07 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'm not going to play with Ratsmoker's FAQ - because I can't It's in a place that's off-limits to me, and above all, it's an old OLD link that is being (or should be) fazed out over time. The right thing to do would be to make a tech article out of the FAQ and add the drill-bit test, or at least, a link to this thread.
I'll put it on my to-do list
For the time being, this thread will BE the post that comes up when you search for "drill bit test" in the FE forum.
If you click on Search above, go to Advanced Search, and put in "+drill +bit +test" and select Search Titles Only, and select the FE forum.
Old Sep 24, 2007 | 06:01 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Sounds good Art. Dave said to post whatever you like. No problem.
Old Sep 27, 2007 | 09:05 PM
fairlaniac's Avatar
fairlaniac
Images of drill bit test
Old Sep 27, 2007 | 09:13 PM
RustyTrustyF150's Avatar
RustyTrustyF150
picture speaks a thousand words
Old Sep 28, 2007 | 05:45 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I agree thanks for posting that.
Old Sep 29, 2007 | 03:53 AM
f700's Avatar
f700
drill bit test
hi all i did to a 330ft and found it was 428/406/361/391
joey2fords
Garage & Workshop
26
Jun 15, 2014 06:16 AM
Jerry Chaney
May 2, 2014 10:53 AM
WGS
Dec 1, 2013 02:03 PM
tje2015
16
Mar 3, 2012 07:02 PM
ponch37300
Jul 3, 2006 06:47 PM
