Found a block 352?
Old Feb 16, 2011 | 09:32 PM
MartyRayII's Avatar
MartyRayII
Found a block 352?
I found a block in my girlfriends basement her father was a mechanic and is no longer with us I was trying to figure out what engine this was. all I found on it was 352 and c6me can anyone help with this? Thanks
Old Feb 16, 2011 | 09:54 PM
Sleepy445FE's Avatar
Sleepy445FE
Well it could have been several things. Sadly FE's are virtually impossible to identify by casting number(with a few exceptions).
The C6ME block is listed as:
1966-68 428 4.13" bore
1966-67 410 4.05"
1968-76 360 4.05"
the latter two are exactly the same, with the only difference being the rotating assembly that was used. As to the 428, I'm not 100% sure(have never had the luck of finding one), but I think the 428's had a scratch mark "A" on the back. I would just measure the bore, see what it's at, and if you're gonna build it you'd have it sonic checked anyways. Then you would know for sure if it "could" go to a 428 bore. Just my 2cents.
Old Feb 16, 2011 | 10:03 PM
MartyRayII's Avatar
MartyRayII
I am gonna clean it up tomorrow and see if I van get some more id # on it. and I forgot to add the a on the end its c6me-a
Old Feb 16, 2011 | 10:17 PM
Sleepy445FE
C6ME-A
1967 352 4.00" bore
1968-76 360 4.05"
1966 390 4.05"
1966-67 410 4.05"
1966-68 428 4.13"
Pretty much the same stuff. I'd be skeptical of the 428, given all it's availability in the smaller bore block. MOST of the 352/360/390/410 blocks will not go .080 over. Get it cleaned up and bore measured and you'll know more of what you have. Who knows it may be a 428 block, he kept it for a long time maybe that's why.
It's a hydraulic lifter block by the way.
Old Feb 16, 2011 | 11:20 PM
MartyRayII's Avatar
MartyRayII
Thanks for the info i really appreciate that, will try to measure the bore to and see what it is.
Old Feb 17, 2011 | 08:08 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Since it's the bare block, measure the bore. That'll tell you what you have more than anything else.
Old Feb 17, 2011 | 05:36 PM
captchas's Avatar
captchas
Guest
if you see a cast in 352 on the left side front water jacket below the head suface it is a 352.
Old Feb 17, 2011 | 06:02 PM
MartyRayII's Avatar
MartyRayII
It has 3.5 stroke and 4 inch bore roughly 7f5 imguessing is the date stamp and found 040 on the top of the piston
Old Feb 17, 2011 | 06:06 PM
MartyRayII's Avatar
MartyRayII
I don't want to build it I like my 4.9 300 I am going to try to trade it or sell it torwards another 300 to work with thanks for all the info guy yall are always very helpful.
Old Feb 17, 2011 | 06:25 PM
krewat's Avatar
krewat
Actually, that's not true. It can be almost any FE, a 352, 360, 390, etc.
Old Feb 17, 2011 | 06:37 PM
Sleepy445FE
Yeah almost all FE's have 352 cast into them. That or they have a mirror 105.
Too bad you dont want to build an fe. The 300 is great too though. Glad we could help. Good luck with it!
Old Feb 18, 2011 | 07:17 PM
captchas's Avatar
captchas
Guest
playing with a 352 in my shop right now. it's in a 1963 gal 500xl convert. pita won't start.
art it's funny as this one has 352 cast right into the left front of the block another ford we have has a 406 and it has that cast into it's block. ford can drive a mechanic crazy.
duke_boy
23
Jun 26, 2011 02:04 AM
abc2129
Mar 28, 2011 07:23 PM
wagonerkl
Sep 1, 2010 12:03 AM
ford fisherman
Jan 31, 2006 01:54 PM
fordsnharleys
Oct 18, 2001 08:01 PM
