Boring a 390
Old Mar 5, 2009 | 11:18 PM
shephard199's Avatar
shephard199
Boring a 390
Can any 390 be bored 80 over to be made a 428 with no problem.
Old Mar 5, 2009 | 11:29 PM
maxtor's Avatar
maxtor
The short answer is no. Have your block sonic tested to make sure how far you can bore your block safely.
Old Mar 5, 2009 | 11:46 PM
85e150's Avatar
85e150
No. Even if your block didn't have core shift, had the right thickness etc, you risk ending up with really thin cylinders. If you must, as per previous post, get it sonic checked. Read first:
https://www.ford-trucks.com/forums/2...questions.html
Remember, to make a 390 into a 428, you need the bigger bore, and you need a longer stroke. So, do what Ford did. Just add the stroke. With the stock bore, it's the 410 from '66-7 Mecurys.
Best to have the thickest cylinder walls you can anyway.
If you want to go bigger, a stroker crank can be had to give you a 445:
www.ScatCrankshafts.com
Old Mar 6, 2009 | 01:33 PM
Bear 45/70's Avatar
Bear 45/70
I did it many years ago, but the block was one of the 375 horse Hi-performance blocks. For stand block it is just not possible for most of them.
Old Mar 6, 2009 | 02:05 PM
shephard199
alright ill probably have it sonic checked, my reason for this question was I was wanting to turn my true 428 into a stroker/roller motor and take all my brand new parts and put them in a 390 thats bored so I dont loose money in them and the 390/428 would be goin in a 78 bronco but now Ive been told its hard to put a 390 in a 78 bronco that a 460 would be easier and i have one of those also so i dont know. Decisions Decisions
May 10, 2017 07:33 PM
Nick-1973-ford
Sep 7, 2016 06:33 PM
BelJask
May 3, 2016 06:19 PM
Tuttle69
May 23, 2014 02:32 PM
SuperFord
Sep 17, 2004 10:17 AM
