Block heater??
Old Nov 19, 2014 | 02:55 AM
Yahiko's Avatar
Yahiko
Look here
Sean
Old Nov 19, 2014 | 06:26 AM
KDAVID1's Avatar
KDAVID1
Originally Posted by Yahiko
Look here
Sean
Cool. That should be easy to find.
2006 F350 4X4
Old Dec 7, 2016 | 11:17 PM
BigGreenEx's Avatar
BigGreenEx
Look here
Sean
Used the search function like everyone says to, took me a while, but Yahiko never fails to amaze me with his willingness to help. The only post I was able to find that actually explained and showed where this damn heater cord is located, my truck is now plugged in and should be warm in the morning.
Old Dec 7, 2016 | 11:43 PM
Yahiko's Avatar
Yahiko
I had forgotten about that photo. I see one other thing in it that is
worth pointing out. The end of the arrow you can see the cord and a
metal clip. That clip is what holds the plug into the connector on the
heater. To remove it you just have to reach up and wiggle that clip
off the heater and then it will easily unplug from the heater.
Old Dec 8, 2016 | 09:15 PM
87crewdually's Avatar
87crewdually
Sean
6.0L Tech Folder
The newer trucks 2005+ didn't come with cords unless the dealer ordered it with it so many won't have it. Also the replacement cord plugs into the heating element and then is held on with a large collar nut. I put them on hand tight.
Old Dec 9, 2016 | 01:06 AM
Yahiko's Avatar
Yahiko
Good to know that. Mine is held on with that metal clip device.
Old Dec 9, 2016 | 02:58 PM
Euroman's Avatar
Euroman
To route it to the front I took the bumper off and it was pretty easy...
Old Jan 2, 2017 | 08:51 AM
dlynes's Avatar
dlynes
Are you saying the 2005/newer came with it already installed in the block but the cord is not included or was it an orderable option for both?
I have a 2006 but I do not see the cord and I did not inspect further to see if there was anything on the block.
Old Jan 2, 2017 | 12:22 PM
87crewdually
Your truck came with a block heater. Cords were optional order item.
Look just above the starter.
Old Jan 2, 2017 | 04:54 PM
Yahiko's Avatar
Yahiko
Look here
Sean
If you look atthe starter you should be able to see if there is a cord installed or not.
In the photo you can see the cord hanging down. It was moved a bit out of place but
you should be able to find it if you do have one.
Old Jan 2, 2017 | 10:08 PM
dlynes's Avatar
dlynes
good to know!! thanks! ill check mine.
Tact
Dec 12, 2013 02:26 PM
hansen
6.4L Power Stroke Diesel
Nov 19, 2010 12:48 PM
trike1946
Jan 14, 2009 07:02 PM
briancowart
Dec 13, 2007 11:12 AM
ishootskeet
Feb 14, 2003 11:28 PM
