I have a 2006 F250 6.0 CC. I'm pretty sure that the truck has an engine block heater but I am having my doubts about the cord already being installed. Can someone tell me EXACTLY where to look under the hood to find the heater. From what I have read you can see the prongs come off the block where the cord plugs in under the hood. Ive looked all in the front bumper for a cord and can't find one so I'm assuming it isnt there. I just need someone to give me pretty detailed instructions on where to look for the prongs that the cord plugs into.
Thanks,
Brian
All 6.0 come from the factory with the block heater installed, not all have the cord attached from the factory however. If the cord is there, it will be zip tied up above the passenger side tow hook, behind the bumper and there is a cap covering the plug.
I ran into this issue myself. If you still have your window sticker you can look at that. If it has the cord installed it will be listed as an option (I believe it is $25 or something like that).
Would you guys that have added a cord reccomend purchasing the ford one with all the clips and tabs or just buying the straight cord and zip-tying it where it needs to go?
I got mine at the local International dealer for twenty-something bucks. It was a no frills one with no clips but it only took 20 minutes or so to route it and zip tie it down.
i did not get that option on my truck but would like to install one. does anybody have the part number for the international part? I'd rather not spend 120.00 on a cord if I don't have to.
