block heaters
Old Feb 14, 2003 | 10:13 AM
ishootskeet's Avatar
ishootskeet
block heaters
I have a 96 F350 Crewcab dually. 7.3 powerstroke. Did block heaters come standard on the powerstrokes? If so, where would I find the plug???
Old Feb 14, 2003 | 11:47 AM
bluecon1's Avatar
bluecon1
block heaters
If I remember correctly, it should be behind the bumper/grill more to the drivers side. It may be best to follow it from the actual block heater, located by the oil filter. I know the block heaters are a standard item in my area here in Canada.
Old Feb 14, 2003 | 12:47 PM
knocturnal's Avatar
knocturnal
block heaters
yea its behind the bumper on the drivers side sorta.. it might be tucked in there neatly i found it easier to look from the driver side wheel well and look behind the bumper if light is an issue use a flash light it will be there
Old Feb 14, 2003 | 03:45 PM
bilder12's Avatar
bilder12
block heaters
I do believe all the diesels come with the block heater. The factory certainly has a nack of hiding the electrical cords. Try behind the bumper or lower part of the grille. they can be found easier by looking for the block heater unit and follow the wire from there. It will be the only 110 volt type of wiring in the engine compartment.
Old Feb 14, 2003 | 09:53 PM
wingit1x's Avatar
wingit1x
block heaters
On my '97 it was bundled between the driver's side headlamp and the radiator....
Old Feb 14, 2003 | 11:28 PM
Redjackt88's Avatar
Redjackt88
block heaters
i tried for 2 weeks to find the plug on my 02 f-250...i finally decided it did not have a block heater. the next day a friend of mine walked up to the truck reached inside the bumper by the right tow hook and pulled it out.....I LOOKED THERE! and more than once.
