Grunt
Old Oct 19, 2014 | 07:50 PM
Lastwagen's Avatar
Lastwagen
Grunt
When I turn right into a ramped driveway or the like I hear a short "grunt" sound like a tire tread is rubbing. Everything is stock and I have looked closely for where a front tire might rub. Nothing. Could it be the differential? Never heard that on the 2012. My Corvette will do some popping from the diff when I turn short and it's still cold but that stops after it warms up.
Old Oct 20, 2014 | 05:14 AM
senix's Avatar
senix
Wonder if it is the slip joint for the driveshaft.
My rear diff will pop on a really tight turn. I have a LS.
Do you have a LS rear?
Old Oct 20, 2014 | 06:44 AM
Lastwagen's Avatar
Lastwagen
"Do you have a LS rear?"
Yes and I did drain the fluid, refilled and put a suggested additive in for limited slip when the car was new. That seemed to help a lot.
This on my truck sounds much more like a rub. Probably nothing to worry about anyway.
Old Oct 20, 2014 | 03:04 PM
superrangerman2002's Avatar
superrangerman2002
I get something similar on my '12 when turning right into a upwards sloped driveway or approach. To me it sounds like loose box or cab mounts.
Old Oct 20, 2014 | 07:14 PM
ruschejj's Avatar
ruschejj
I can hear rubber/door seals complaining a bit when driving into steep driveways where the frame gets torqued. That my guess, I think everything flexes a little.
Old Oct 20, 2014 | 07:31 PM
Lastwagen's Avatar
Lastwagen
It could be either of the last 2 posts. Maybe one of the rubber bushings between the frame and cab or frame and box. No worries, just an observation. You know how it is when switching to a new truck and everything seems quiet and smooth for a while. I'm sure more little sounds will surface.
Old Oct 21, 2014 | 11:23 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by Lastwagen
When I turn right into a ramped driveway or the like I hear a short "grunt" sound like a tire tread is rubbing...
Hi gang,
If your truck is making a new noise or something just doesn't sound right, you can always have your dealer take a look. Let us know what you find out and don't hesitate to let me know if you need some additional help.
Crystal
Old Oct 21, 2014 | 12:05 PM
ciscofreak's Avatar
ciscofreak
That is the over-active traction control. Mine is ultra-sensitive and does it any time I hit a small divot in the pavement while turning. Try turning off the traction control and it will magically disappear.
Old Oct 21, 2014 | 01:10 PM
Lastwagen's Avatar
Lastwagen
I'll give it a try. Never even entered my mind. But yes that could be what I'm hearing.
Old Oct 21, 2014 | 01:27 PM
yfz 450's Avatar
yfz 450
I have the exact same problem with my 14
Cornbread56
27
Jun 13, 2015 10:45 AM
kmitz05
Nov 15, 2011 04:35 PM
bfgfocus
Jan 13, 2011 07:11 PM
Gary_W
May 20, 2010 06:50 PM
260falcon
Jan 29, 2006 12:02 PM
