Limited slip
Old Jan 28, 2006 | 10:01 AM
260falcon's Avatar
260falcon
Question Limited slip
Is there a way to see if a rear end has Limited slip without tearing it apart? It is in a car from the mid 60's Looks like a 9"
Thanks
Old Jan 28, 2006 | 10:30 AM
DaveBowman's Avatar
DaveBowman
Yes, you can jack one tire off the ground and with the transmission in park see if you are able to turn that tire with little effort. If it spins easilly its not a limited slip axle. If you are not able to turn it, or it takes a lot of force to do so its probably a limited slip.
Old Jan 28, 2006 | 10:41 AM
fordraceboy's Avatar
fordraceboy
unless.... it's a clutch style limited slip and the clutches are worn a bit and don't have a lot of friction when its cold.. take it for a good long drive and maybe light the tires a bit to make sure everythings hot inside, then try the jack test.. jmo
Old Jan 28, 2006 | 12:19 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Jack up both rear tires, tranny in neutral, and spin one tire by hand. If the other tire turns in the same direction, its a LS. If the other tire turns in the opposite direction, its an open diff.
Old Jan 28, 2006 | 12:38 PM
76 F-150 390FE's Avatar
76 F-150 390FE
you can also look for the tag on one of the bolts for the 3rd member. the 1st numbers on the bottom row will be the gear ratio. 3 50 is 3.50:1 open and 3L50 is 3.50:1 limited slip.
Old Jan 29, 2006 | 12:14 AM
Uglyhat's Avatar
Uglyhat
What ATC Crazy sez is how I was told you could tell ... but ... what I've done to tell if my own LS is working properly is break traction on some sort of low friction surface - gravel or grass works. If I get spin on both wheels I figure it's OK. Ex-wife's front yard is a perfect place for this.
Old Jan 29, 2006 | 10:20 AM
DaveBowman's Avatar
DaveBowman
My F450 doesn't have a LS rear and it usually spins both rear tires in the grass or slick mud, so this really isn't the best way to tell.
And its sven possible to have a limited slip axle and only get one tire spinning on a low froction surface such as mud or wet grass (especially with an old, high milage axle) because the clutch pack might not be loaded enoufgh to turn both tires togethar.
Old Jan 29, 2006 | 12:02 PM
260falcon's Avatar
260falcon
Talking
Thanks a lot Guys This car does not run but without jacking it I did see a tag on the rear end -20 here today so will jack it up and look at the tag on a warmer day. I do like Uglyhat's idea about try it on the EX's Lawn. but might dent somthing knocking down the fence first.
Thanks again
