Sponsored by: Real Truck
Rear diff locked
Old Nov 15, 2011 | 04:00 PM
kmitz05's Avatar
kmitz05
Rear diff locked
I have a 2000 7.3 and I noticed during a brake job that the rear wheels are locked together. This can't be normal. The tires spin freely but when you turn one the other spins with it. No wierd noises or anything.
I need some help fixing this.
Old Nov 15, 2011 | 04:03 PM
SteveH-CO's Avatar
SteveH-CO
You may have the limited slip diff - check for an 'L' in the diff tag - like 3L73 - meaning 3.73 ratio, limited slip. Unless the diff is locked up solid (as in, it chatters when you make a U-turn), you have nothing to worry about. The PO may have also installed a real locker, too.
Old Nov 15, 2011 | 04:10 PM
kmitz05's Avatar
kmitz05
So this is normal? It does have a little play and is not locked up solid. I can spin one tire to about 1 oclock before the other starts to turn.
Old Nov 15, 2011 | 04:22 PM
rs4-380's Avatar
rs4-380
do they spin in the same direction or opposite directions?
Old Nov 15, 2011 | 04:35 PM
dchamberlain's Avatar
dchamberlain
It's normal for a limited slip differential, which you probably have. Find an empty place in a parking lot and do the tightest circles you can do. As long as the rear tires are not chirping you are fine.
GT4point6
Feb 8, 2020 12:49 PM
rendog84
Dec 12, 2009 06:31 PM
mikebadass76
Feb 11, 2008 09:46 PM
Iron Horseman
Oil & Lubrication
Jan 30, 2006 01:42 PM
lostbuckaroo
Jun 26, 2003 09:59 AM
