Sensor Module Park Aid
Old Oct 10, 2014 | 11:22 AM
ohiodallas's Avatar
ohiodallas
I have a 2005 Ford Excursion Diesel 6.o Liter with a right rear sensor module park aid out. Ford has notified me that the part has been discontinued.
The part number is 1C7Z15k866AA.
I would appreciate if someone could inform how to research this part if its still out there.
Thank you !!
Old Oct 13, 2014 | 10:49 PM
superdave02f552's Avatar
superdave02f552
I have read with a slight mod the pickup ones will work I will see if I can find it
Old Oct 14, 2014 | 08:34 AM
David - WI's Avatar
David - WI
Wrong part, sorry. They seem to be available online: http://oemfordparts.jackyjones.com/oe-ford/1c7z15k866aa
Old Oct 14, 2014 | 09:35 AM
ohiodallas's Avatar
ohiodallas
Rear Sensor
Thank you!
ohiodallas's Avatar
ohiodallas
Thank you. I greatly appreciate it.
Old Oct 14, 2014 | 02:55 PM
jpr38057's Avatar
jpr38057
Thank you !!
The part number you have is for the module that controls all the sensors and mounts inside the truck. You mention you need the right side? If you need the sensor in the bumper, the part # is 1L1Z-15K859-AA which is still available from Ford. Not cheap though.
Old Oct 14, 2014 | 03:35 PM
ohiodallas's Avatar
ohiodallas
Thank you. Yes, they thought it was the sensor in the bumper but that didn't work so I need that module that mounts inside on the right side.
Old Oct 14, 2014 | 08:57 PM
David - WI's Avatar
David - WI
I posted the info for the sensors first because I thought the same thing... then the part number was different so I changed my post... but I bought all 4 sensors on Ebay for about $50. Work great.
Old Nov 29, 2015 | 06:16 PM
shoreline's Avatar
shoreline
Back from the dead!
I need the parking module for a 2005 Ex as well, after replacing everything else. I have clicking in each sensor and the speaker works when tested with a battery. Did you ever find a replacement part? The part number on mine is 1C7T15K866AA, but I have seen this referenced as 1C7Z.... and also as "15K866." Hopefully someone has a lead or I am going to look into the reverse camera.
Old Jun 10, 2016 | 10:30 AM
garrickg's Avatar
garrickg
Did this ever get resolved? I followed the link with no success. I have started a thread with the same request but was wondering if you guys had any luck. Thanks!
Old Jun 10, 2016 | 06:31 PM
Aaron_Jones's Avatar
Aaron_Jones
a couple of suggestions here: P.A.M. For 2003 EX
johntpr
Jan 23, 2018 09:22 AM
64fordf100292
Dec 9, 2009 10:19 AM
Miguy
Mar 21, 2009 07:54 PM
jaferro
2004 - 2008 F150
Aug 30, 2008 03:23 PM
firebug
Nov 2, 2006 03:45 PM
