Having a difficult time finding a replacement reverse sensor/parking aid module for my 2002 Excursion 4x4 Limited. Discontinued by Ford. No luck so far with junkyards etc. The 4x4 version is different than the 4x2.
It's in the interior rear cargo area behind the rear passenger side jack storage panel behind where the jack sits. It is black with white label.
There is a label on it that says Excursion 4x4 1C7T-15K866-AA.
Anyone have any suggestions or can offer assistance?
The Gold Mine is getting an Excursion to scrap soon. I will check it to see if it had that feature when it arrives. It is a V10...supposedly it is all still in once piece.
Yes, speaker is fine. The sensors have been changed twice. My issue is it beeps 90 per cent of the time when nothing is behind it. Don't know what else it could be. Wiring and switch are fine.
Check the angle of your bumper. It must be perfectly level or pointed ever so slightly upward. Same goes for the sensors mounted IN the bumper. Otherwise, the system will pick up ground clutter when the beam hits the ground. I posted testing procedures recently in another thread in here.
