I have a 2005 Ford Excursion Diesel 6.o Liter with a right rear sensor module park aid out. Ford has notified me that the part has been discontinued.
The part number is 1C7Z15k866AA.
I would appreciate if someone could inform how to research this part if its still out there.
Thank you !!
The part number you have is for the module that controls all the sensors and mounts inside the truck. You mention you need the right side? If you need the sensor in the bumper, the part # is 1L1Z-15K859-AA which is still available from Ford. Not cheap though.
I posted the info for the sensors first because I thought the same thing... then the part number was different so I changed my post... but I bought all 4 sensors on Ebay for about $50. Work great.
I need the parking module for a 2005 Ex as well, after replacing everything else. I have clicking in each sensor and the speaker works when tested with a battery. Did you ever find a replacement part? The part number on mine is 1C7T15K866AA, but I have seen this referenced as 1C7Z.... and also as "15K866." Hopefully someone has a lead or I am going to look into the reverse camera.
Did this ever get resolved? I followed the link with no success. I have started a thread with the same request but was wondering if you guys had any luck. Thanks!
