Power Windows
Old Oct 9, 2014 | 07:04 PM
Dudebro's Avatar
Dudebro
Power Windows
My power windows in the back dont go up or down. I can hear the motors, but, no movement. Is there a gear that is stripped? Do I need a new motor?
1995 F350
Old Oct 9, 2014 | 10:05 PM
tbugher62's Avatar
tbugher62
Yes the gear's are probably bad,so you will need to install new motor's.
Old Oct 9, 2014 | 11:03 PM
GuitarJesus's Avatar
GuitarJesus
the power window motors have a set of plastic bushings that crumble and break down over time. I believe you can find them in the help section of the auto parts store. Although instead of using the plastic bushings I just used metal nuts
Old Oct 10, 2014 | 01:17 AM
Crewcabber's Avatar
Crewcabber
Guitar is right. I just replaced the motor on my rear passenger door because it was bad. You have two choices you can either drill out the rivets and replace them with rivets or bolts. Or do like I did and drill two holes to get to the motor bolts.
Old Oct 10, 2014 | 04:47 AM
Dudebro's Avatar
Dudebro
Thanks
Thanks for the help. I will order the new motors.
You drilled holes through the metal on the door? Large enough for a socket?
Old Oct 10, 2014 | 08:57 AM
tbugher62's Avatar
tbugher62
Yes you drill the hole's,it make's it easier and the holes are covered up by the door panel's anyway,and if you ever have to replace them again the hole's will already be there.
Old Oct 10, 2014 | 09:19 AM
Nothing Special's Avatar
Nothing Special
I know there are a bunch of threads on here telling how to fix window motor gearboxes like that. But when I tried to fix a rear window motor on my crew cab that was not how it was. I know the rear and fron motor assemblies are different part numbers. Apparently they are quite different from each other in construction too.
macintn
May 12, 2007 04:39 PM
whirredup
Aerostar
Nov 2, 2006 11:41 PM
cowboyfordman
Jun 27, 2004 09:01 AM
kmansford
Jun 22, 2003 11:45 PM
Dialtone
Mar 31, 2002 08:33 PM
