Power window problems
Old Jun 26, 2004 | 02:43 PM
cowboyfordman's Avatar
cowboyfordman
My 1986 Ford F250 with power windows.....driver side goes down fine, but will not come back up unless you pull up on the glass. The motor is working but seems to be slipping......any help would be appreciated. Thanks.
Old Jun 26, 2004 | 03:11 PM
nzabka's Avatar
nzabka
There is a plastic worm gear at the output of the motor that is broke. Most parts stores carry the replacement plastic gears with new grease. I think I got mine at O'rielly's when it broke. After taking of the inside door panel, you'll have to drill two holes (there are indents where the screws are mounted) to access the bolts that hold the motor in place. After getting the bolts loose, just work the motor out of the hole in the door. You'll see where the gear is/was at the motor enclosure and the rest should be a piece of cake.
Old Jun 26, 2004 | 03:40 PM
cowboyfordman
nabka,
Thank you very, very much, not only for your advice but your quick response. It is nice to know there are people like you out there who are willing to help. Thanks.
Old Jun 26, 2004 | 11:12 PM
nickmobile67's Avatar
nickmobile67
Welcome cowboy! stick around, you'll learn alot here!
Old Jun 27, 2004 | 09:01 AM
nzabka's Avatar
nzabka
Originally Posted by cowboyfordman
nabka,
Anytime.
