Rear power windows
Old May 12, 2007 | 02:06 PM
macintn's Avatar
macintn
Rear power windows
Hello....I own a 1991 EB 4-door Explorer.Awhile back I repaired the 2 front power windows using the nylon bushing fix.Now I would like to do the same with the rear ones.The only problem is the motor appears to be riveted to the door frame.Could someone tell me how to remove this motor properly? Also if the rivets must be drilled out to remove the motor how do I reattach the motor after it is repaired? I have no rivet gun is why I ask.Thanks for any assistance in advance.
Old May 12, 2007 | 04:39 PM
steve(ill)'s Avatar
steve(ill)
normally you drill out or grind off the rivets, then reinstall with slight bigger sheetmetal screws, or #12 bolts and nuts.
