Torque wrench?
Old Sep 21, 2014 | 05:41 PM
Blue and White's Avatar
Blue and White
I have an older Craftsman beam type for sensitive work and a "Tool Shop" (Lowes, Menards?) clicker for other stuff. Both work well. The beam type never needs calibration so I use it for things like internal engine fasteners.
Old Sep 21, 2014 | 05:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
One thing to consider also. On the digital version, if it's not used much, I would remove the battery between uses.
I've seen a lot of electronic equipment damaged/destroyed by leaking or corroded batteries.
Plus, if it's going to sit for a year or longer between uses, the battery will be bad anyway.
Take it out before you store the tool away.
Old Sep 21, 2014 | 07:45 PM
jimlj's Avatar
jimlj
I have a HF clicker wrench. I don't have a clue how accurate it is, but I know it is far more accurate than the half inch ratchet and clenched butt cheeks I had been using. I mainly use it to tighten lug nuts and I have not had a warped rotor since I bought it.
Old Sep 21, 2014 | 08:23 PM
GM4WALLS's Avatar
GM4WALLS
Thank all of you guys for your input. I am making some purchases tomorrow.
Old Sep 22, 2014 | 06:03 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Keep in mind there are two diff "clicker style" torque wrenches. One you screw handle to adjust and must be returned to zero after using. The other uses a small **** to adjust and does not require resetting to zero when storing. I picked up all of mine on E-Bay used. All Snap-On, no digital. I had one digital, but resold it as I didn't like it. Been using all of them for 12 years. I'm not a Snap-On fan, but they have served me well. Worth the money if you are more than a "one project" type of guy.
Old Sep 22, 2014 | 07:14 AM
emeraldcoupe's Avatar
emeraldcoupe
I own an older craftsman 1/2" clicker, a couple of craftsman 1/2" beam, and also the harbor freight 3/8 and 1/2" clickers. all the clickers match the beams for torque. also, the HF tq wrenches usualy are within spec on the calibrations when tested, plenty of info out there on them.
fwiw, i put my engine together with the HF one and it's fine.
Eastland
Nov 25, 2011 09:18 PM
ford2go
Garage & Workshop
Aug 23, 2010 07:12 AM
JaredMackall
Garage & Workshop
33
Sep 26, 2004 12:09 PM
Fordman65
Garage & Workshop
Sep 27, 2003 12:02 AM
micah
Jan 3, 2000 11:44 AM
