Torque Wrench Question
Old Nov 24, 2011 | 08:22 PM
Eastland's Avatar
Eastland
So if I am going to buy only one would you get a ft-lb or in-lb wrench?
Hoping to have an ex to work on here soon and the 01 escape is in need of some care as well, needs new struts, and some coils replaced.
Any recommendations, sears has them for half off right now.
Thanks,
Old Nov 24, 2011 | 08:41 PM
dosecobanya's Avatar
dosecobanya
Buy both, if they're half of it's like buying one, and you're gonna need both of them at some point on this long adventure we call "wrenchin". Just say the turkey made you do it if anyone asks.
Old Nov 24, 2011 | 08:47 PM
dosecobanya
Just skimmed didn't read, sorry. Get the ft-lbs. it's the "big brother" and you'll use it more imo.
Old Nov 24, 2011 | 10:02 PM
BassFantasizer's Avatar
BassFantasizer
At some point you'll want both, but start with the ft-lb scaled wrench. All of the "mechanic" work will use it, but the daintier stuff will be measured in inch-pounds.
Do NOT put a ft-lb scaled torque wrench on something that calls for torquing to inch-lbs and try and convert in your head. You'll pull the threads right off of something.
You can always go get the in-lb wrench later....
Old Nov 24, 2011 | 10:16 PM
jh818's Avatar
jh818
I have 3. One in inch-lbs up to 240 (20.8 ft-lbs.). One from 20 ft-lbs. to 100 ft-lbs. One from 50 ft-lbs. to 190 or so. First 2 are 3/8" drive, the last is 1/2" drive.
I obtained them from the money I saved doing work myself instead of taking my vehicles to the shop.
If you're going to replace struts, get the high ft-lb one. I did struts on my Camry and it called for 165 ft-lbs.
Old Nov 25, 2011 | 09:18 AM
MikeRizz's Avatar
MikeRizz
I have a Snap-On 3/8 digitial that will do both foot lbs and inch lbs. That being said, I have never used the inch lbs.
Old Nov 25, 2011 | 09:18 PM
wallz's Avatar
wallz
You will need the larger one if you do any kind of wrenching on the X, 165 for the tires, over 200 for some of the suspension stuff. You will need the smaller one for some of the finer, like spark plugs stuff or you smaller vehicles. Get both if you can.
GM4WALLS
20
Sep 22, 2014 07:14 AM
Ruckus
Garage & Workshop
24
Mar 29, 2005 04:15 PM
grease monkey
Garage & Workshop
40
Dec 18, 2004 08:36 AM
JaredMackall
Garage & Workshop
33
Sep 26, 2004 12:09 PM
Fordman65
Garage & Workshop
Sep 27, 2003 12:02 AM
