Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Torque wrench recommendations
Old Aug 14, 2010 | 04:50 PM
ford2go's Avatar
ford2go
Hi,
Well, I'm getting religion, and I thought that I'd get a torque wrench to use on my lug nuts. I also have some small engine stuff and a lifetime project car to use it on.
I thought that a beam type would be OK, especially since they are supposed to stay in cal. I looked at Sears, and the only reasonably priced one was a clicker that everyone rated as junk.
Any thoughts? I know that a clicker is more convenient, but I have an inch pound beam type, and it seems to work OK.
Thanks,
Old Aug 15, 2010 | 11:55 AM
bleeds-ford-blue's Avatar
bleeds-ford-blue
for occasional home use, go with the beam-type Craftsman, 1/2" drive, ft/lb model....if you are trying to earn a living with it, go with the Snap-on clicker type.
even if you're a pro, the beam-type from Craftsman is fine for occasional use- I still have one in my box at work
Old Aug 16, 2010 | 01:21 AM
ford2go's Avatar
ford2go
Thanks,
I went back to sears and used beam with the search and it showed up.
When I just searched on torque wrench earlier I didn't see this wrench, and I thought that maybe they had discontinued it.
Looks like a good deal for what I need.
Old Aug 16, 2010 | 07:02 AM
bleeds-ford-blue
added bonus- last I heard, the Craftsman warrantee covered the beam-type, but not their clicker-type (info is somewhat dated, dunno if it's still current)
Old Aug 16, 2010 | 05:40 PM
dkf's Avatar
dkf
I have a 3/8" drive in lb and a 1/2" ft lb clicker type torque wrenches made by SK. Both came with a blow molded case and cost a little over $100 each. They do everything I need them to do.
Old Aug 23, 2010 | 07:12 AM
ford12508's Avatar
ford12508
I have a craftsman clicker type 1/2", and it works good enough for my home use. I do all my own rotations and remove the wheels a decent number of times a year.
GM4WALLS
20
Sep 22, 2014 07:14 AM
TheHades
Feb 21, 2014 03:46 AM
BeerCan500
Aug 29, 2012 04:12 AM
amish77
Garage & Workshop
30
Aug 7, 2005 10:32 PM
MustangGT221
Aug 30, 2003 10:07 PM
