I have harsh engagement reverse, only 1fwd gear. Everything else seems normal, cleared code. Came right back. Looked for obvious elect problems
Any suggestions would be appreciated. Thanks. V10
Recently bought truck, unknown history. I think problem is electrical. From what I can tell I should have PWR feed to Trans from main module. I only have PWR a I term at Trans connector, from what I read should have 4 terms at Trans with 12v, 7,20,21,24. I read conn b terminal 7(yellow white)feeds this circuit. Can't locate it.
