ok my trans lite has been going on and off for a month now everytime i go to get the code scaned it goes out and they say they cant do anything unless the lite is on. well with in the past week the trans has been making a thud nosie when i put it in to drive or reverse, and when i let off the gas and the hit the gas and when the trans shifts. the previous owner of the truck just had the trans rebuilt 15,000 miles ago so do you guys think that they didnt do something right. one guy i was talking to said it is probably the torque converter that is starting to go and the trans was fine what do you guys think?
Well something is going wrong. It shouldn't do that. Who rebuilt the trans? Was there any warranty on the trans? Was it rebuilt stock or heavy duty? Is the fluid full? Does it smell burnt? Is there a change in how hard it shifts when the lite is on? Have you been towing?
i have do not know who rebuilt the transmission or how they did it i bought it from a dealer so i never met the prev owner all i have is a copy of the receipt but the name of the place was cut off. the trans did have a 90 day 4,000 mile warranty. the fluid level is right where it should be and it is clean and fresh. ihave not been towing and the trans does shift different when the lite is on.
Do you have your foot on the brake when selecting drive or reverse...... if not that would/could be just normal Ford backlash. If you have set a code and NOT turned of the ignition the code should still be there. Give Azone a try for checking the code.
Do the tach and speedo work flawlessly........ when was the last time the (TPS) FIPL was reset........
Since this is not a supercab longbox........check U joints.
my foot is on the brake and the tach and speedo work flawlessly. i dont know when the fipl was last reset i will look at it today. well i took it to a trans shop this moning hen told me when he check the computer that the trans had bumped up the pressure because it is slipping. he said that the whole trans needs to be rebuilt.
I used to live there. nice town. Blue Bell RD. & Corkery Lane. Before you do anything get a second opinion. Call Mark at Shamong transmissions. 609-268-8838. He is on Rt. 206. Then decide what to do and where to do it. Mark is expensive but he does good work. I take all my trucks to him. Atleast find out for sure if it needs to be rebuilt. Tell him Bob Harford told you to call.
thanks alot man i will check him out tomorrow i was going to get a second oppinion but everyone is colsed today. i used to live right near there i am near the shopright now. well ill let you know how it turns out and again thanks
HELLO,
THE SOUND YOU ARE HEARING COULD BE ONE OR MORE THINGS. THE TORQUE CONVERTER, PUMP, TOO HIGH LINE PRESSURE. GIVE US A CALL SO I CAN GET A BETTER IDEA OF THE PROBLEM. WE OFFER DO IT YOURSELF UPGRADES, AND COMPLETE BULLET PROOF TRANSMISSIONS FOR YOUR VEHICLE.
i am going to check the fipl today didnt get a chance to yester day cause the truck is at work. i will probably take it to a few places today to see what they say. thanks
