Sponsored by: Real Truck
06 f550 transmission problem
Old May 31, 2017 | 12:57 PM
l057388's Avatar
l057388
06 F550 w/5r110w. Truck and trans runs great then trans acts like it was shifted into neutral, rpm's flare up and if you don't get your foot out of it the trans will re engage aggressively. Changed the speed sensor on the rear axle, there are no codes, had a trans shop change the filters and fluids then change out all of the solenoids. They tell me its not a trans problem. Any opinions?
Old May 31, 2017 | 02:08 PM
redford's Avatar
redford
FTE Leadership Emeritus
Start with getting a new transmission shop.
Old Jun 2, 2017 | 09:25 AM
l057388's Avatar
l057388
Not any Help Sarge. Curious to know what experiences others have had when the truck acts up but no check engine light or wrench light comes on. I plan to replace the harness from the trans to the ECM. I have 4 F550's with 6.0's but never had this issue.
Old Jun 2, 2017 | 10:14 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
What's their explanation for how it's NOT a transmission problem? There aren't a lot of other parts that will slam together on a vehicle. Unless they consider the TC to not be part of the transmission?
In the transmission manual, Routine 214 for "Feel Concern - Some/All" involves checking line pressure, the fluid pump assembly, and the torque converter (the part that can slam, kind of like your original complaint?), so if they just threw in new solenoids and said "that oughta do'er" then yeah, I echo the sentiment of find a shop that will do a real diagnosis.
Jej8
Aug 10, 2014 08:05 PM
LUMBERMAN
Jan 14, 2008 09:19 PM
Kingtim7
Jan 14, 2007 07:12 PM
davisenvy
24
Nov 11, 2005 08:57 AM
jethro
Sep 23, 2001 08:34 PM
