AE question regarding throttle position sensor
Old Jul 21, 2014 | 09:21 PM
cutlass's Avatar
cutlass
When running AE, I am looking at the "Throttle Position Sensor Status" reading and "Throttle Position Mode". Neither of those will register any data on AE while I'm pushing the throttle pedal. Shouldn't I see something on either of these data outputs?
Thanks,
Drake
Old Jul 21, 2014 | 09:39 PM
white Buffalo's Avatar
white Buffalo
I think on my version of AE it is called accelerator pedal position. I see 12% at idle and up to 74% at WOT.
Old Jul 22, 2014 | 07:53 AM
Tugly's Avatar
Tugly
If you look at the throttle position volts, it will likely peak out at about 3.85 volts while floored. This has been the most common voltage I've seen.
AGrayson84
Nov 8, 2016 02:56 PM
Craig64
Jun 6, 2008 06:42 PM
95STROKER29
Feb 25, 2008 10:43 PM
Torvvald
Mar 10, 2007 06:52 AM
gdoggy
1983 - 2012 Ranger & B-Series
Jun 19, 2003 09:48 PM
