throttle postion sensor
Old Feb 25, 2008 | 08:21 PM
95STROKER29's Avatar
95STROKER29
where is the tps on 95 power stroke
Old Feb 25, 2008 | 08:25 PM
tjbeggs's Avatar
tjbeggs
on the throttle pedal.
Old Feb 25, 2008 | 10:43 PM
iasrap's Avatar
iasrap
It is at the top of the throttle pedal. There are two sensors on the assembly itself. The bottom one is the idle validation switch it looks like a rectangle mounted edge on with a button coming out of it just under the spine of the throttle pedal. The TPS is a small sensor up by the pedal pivot point.
Hope that helps.
