1966 WING WINDOW
Old Jul 15, 2014 | 02:13 PM
Gary Martin's Avatar
Gary Martin
1966 WING WINDOW
My left side 1966 wing window frame shaft is broken and I have a new one, but I'm having a hard time getting the glasss out of the old frame.
Any help you can offer would be greatly appreciated.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Jul 15, 2014 | 03:02 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The glass is embedded in a layer of glass tape in that channel. Glass shops have a special tool to pull the glass out of the channel. If you can't afford to break the glass (date coded originals that you want to save) you might want to take it to the pros. And if they break it they would typically be expected to replace it for free.
However, I did get one of mine out by heating the frame and glass slowly with a heat gun (hair dryer probably not hot enough) and once the tape softened to a point I was able to pull it out of the frame but I had to use some heat resistant gloves as it was burning hot by then.
Your mileage may vary...
Old Jul 15, 2014 | 03:10 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If you go to this link and scroll down a few screens there is a drawing of a tool in use like I'm referring to that glass shops typically have. Fairly common tool and not all that expensive but if you only use it once or twice might not be worth the investment.
http://www.justanswer.com/ford/499yh...nt-window.html
Old Jul 15, 2014 | 04:15 PM
Gary Martin
Thanks for the info, I'll run it down to the glass shop and have the pro's take care of it.
Old Jul 15, 2014 | 09:53 PM
Bob Fonda's Avatar
Bob Fonda
Gary, Might I ask where you found the left vent window frame? the framed window is fine but it is loose and won't stay in one position,i don't see how to adjust it. Thanks Bob
Old Jul 16, 2014 | 04:22 PM
Gary Martin
Bob,
I ordered the new one from LMC Truck, (part & accessories magazine), however if your wing window is just loose you should be able to tighten it up. There is an adjustment nut inside the door, it hard to get to it but it's ajustable if it's not broken.
Thanks Gary
Old Jul 16, 2014 | 08:05 PM
Bob Fonda's Avatar
Bob Fonda
Gary, I thought it was just a pin. thanks for the information I will give that a shot.
Old Jul 17, 2014 | 10:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Jul 18, 2014 | 08:22 PM
Bob Fonda's Avatar
Bob Fonda
Thank you ,very helpful.
4EyedTurd
May 1, 2019 03:04 PM
scottlathrop
Aug 2, 2015 08:04 PM
ungerp
Jan 2, 2013 03:54 PM
littlecobra1977
Nov 7, 2011 08:54 PM
lshort
Apr 16, 2002 07:02 AM
